Введение
Use this guide to replace the lower case.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
6 участников успешно повторили данное руководство.
Один комментарий
Tengo una Macbook Pro Retina Display Late 2012. Pero al leer el tutorial noto que los tornillos que dices son dos de 2.3 mm y los demas de 3.0 mm.
Pero en mi macbook todos son de 1.2 mm. Porqué?
If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
Toby Thurston - Ответить
Or you can use an ice tray where you put the screws and the parts in separate bays in the same order as they come in the instructions.
timofej.se -
The colors of the circles marking the locations of the screws are reversed.
Homer Hegedus - Ответить
On my model A1425 these were all 1.2mm P5 screws. They all looked the same to me.
bigfish333 - Ответить
This is great! I used a small magnetic white board, and wrote on it to identify the parts as I went. This whole process, from the fast shipment to the great instructions to the complete, high quality, tool kit has been great. I’m typing this comment on my resurrected laptop. Thank you! Sue
Susan Greer - Ответить
