Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95-
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
The lower case is connected to the upper case at the center, with two plastic clips.
Remove the plastic cover adhered to the battery contact board.
Remove the following screws securing the battery connector board to the logic board:
Two 2.8 mm T6 Torx screws
One 7.0 mm T6 Torx shouldered screw
Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
Carefully lift the battery connector board up off the logic board.
It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
Lift and remove the I/O board data cable from the MacBook Pro.
Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
Move the SSD cable connector out of the way.
Wedge the pointed end of a spudger beneath the right speaker cable connector.
Gently pry the right speaker cable connector up off from its socket on the logic board.
Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
One black 6.8 mm screw
One silver 6.3 mm screw
One black 4.9 mm screw
Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
Wedge the tip of a spudger beneath the left speaker cable connector.
Gently pry the left speaker cable connector up off from its socket on the logic board.
Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
Now that your MacBook Pro is fully prepped, it's time to prep yourself.
Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
Do not wear contact lenses without eye protection.
Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
Pull off the black rubber stopper from your bottle of adhesive remover.
Use scissors to cut off the sealed tip of the applicator.
Apply a few drops of adhesive remover evenly under the edge of the leftmost battery cell.
Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
Инструмент, используемый на этом этапе:Plastic Cards$2.99-
Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell.
Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
Insert the spudger along the left-hand side of the leftmost battery cell.
Run the spudger up along the left side of the leftmost battery cell.
Slightly pry the leftmost battery cell to release it from the adhesive.
Repeat the above steps to separate the adjacent battery cell from its adhesive:
Apply a few drops of liquid adhesive remover under the battery cell.
Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
Carefully wedge a spudger or plastic card inwards, being careful to not damage the battery, and separate the battery cell from the adhesive securing it to your MacBook Pro.
Insert the flat end of a spudger underneath the larger leftmost battery cell.
Carefully wedge the spudger inwards, being careful to not damage the battery cells.
Pry the larger leftmost battery cell up off the upper case.
Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case.
Leave the battery cells resting on top of the upper case as shown in the third picture.
Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro.
Remember to add a small amount of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell.
Lift the battery as a whole up out of the upper case, and remove the battery.
With a little luck, you can slowly pull out each strip of adhesive with your fingers.
Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
Wedge the flat end of a spudger underneath the keyboard backlight connector and the logic board.
Gently twist the flat end of a spudger upwards to pry the keyboard backlight connector up off its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Grasp the plastic pull tab and pull the trackpad ribbon cable out of its socket.
Use the tip of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Grasp the plastic pull tab and pull the keyboard ribbon cable out of its socket.
Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
Grasp the plastic pull tab and pull the microphone ribbon cable out of its socket.
Use the tip of a spudger to rotate the pull tab secured to the display data cable lock toward the DC-In side of the computer.
Gently push the edges of the display data cable connector away from its socket on the logic board.
Pull, but do not remove, the display data cable connector out of its socket and carefully move it out of the way.
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
Carefully pull the left fan ribbon cable out of its socket.
Move the left fan ribbon cable aside to reveal a hidden screw securing the logic board assembly to the upper case.
Remove the following screws securing the logic board to the upper case:
Eight 3.3 mm T5 Torx screws
One Phillips #00 screw
Two 3.1 mm T5 Torx screws
Remove two more screws, from the MagSafe DC-In board in the upper right corner (second image).
Two 3.4 mm T5 Torx screws
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding any cables and the I/O ports that may get caught during removal.
Pull the right I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Remove the following two screws securing the I/O board to the upper case:
One 3.53 mm T5 Torx screw
One 4.89 mm T8 Torx standoff screw
Carefully pull and remove the I/O board away from its recess in the upper case.
Remove the two 3.4 mm T5 Torx screws securing the headphone jack to the upper case.
Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
Remove the 3.2 mm T5 Torx screws (one on each side) securing the aluminum hinge brackets to the upper case.
Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
Remove the last remaining T8 Torx screw securing the display to the upper case.
Grip both halves of the device, one in each hand.
Gently push forward on the bottom half of the device to detach it from the display assembly.
Carefully set each component aside, making sure to set down the lower half keyboard-side down.
Remove the following screws securing the trackpad to the upper case:
Four 1.4 mm Phillips #000 screws
Wedge the spudger between the trackpad ribbon cable and the upper case.
Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
Insert the tip of a spudger in between the trackpad ribbon cable and the upper case.
Carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
Once the trackpad is free of the upper case, guide the trackpad ribbon cable through the slot cut in the upper case.
Remove the trackpad from the upper case.
For this step, it is recommended to use a heat gun or hair dryer to soften the adhesive securing the microphone assembly to the upper case. You may be able to remove it without doing so, but will risk damaging the microphone cable.
With the heat gun set to low, heat the microphone assembly to loosen the adhesive attaching it to the upper case.
Use the tip of a spudger to remove the piece of tape covering one of two microphones.
Grasp the piece of tape with a pair of tweezers and remove it.
Repeat the same procedure as the previous step to remove the tape covering the second microphone.
Wedge the tip of a spudger underneath the microphone assembly cable.
Run the spudger up along the bottom of the microphone assembly cable to separate it from the upper case.
Gently wedge the tip of a spudger underneath the second microphone and push inwards to loosen the adhesive.
Lift and remove the microphone assembly out of the upper case.
14 участников успешно повторили данное руководство.
2 Комментариев
If uppercase Assembly(Includes Trackpad, keyboard, Palmrest & BATTERY) is being replaced, there is no need to remove battery from old uppercase assembly.
