Введение
Use this guide to replace the lower case.
Выберете то, что вам нужно
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
14 участников успешно повторили данное руководство.
