MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement
Выберете то, что вам нужно
  1. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 3, изображение 1 из 2 MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 3, изображение 2 из 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, Battery Connector: шаг 4, изображение 1 из 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 5, изображение 1 из 2 MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 5, изображение 2 из 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 6, изображение 1 из 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, AirPort Board: шаг 7, изображение 1 из 3 MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, AirPort Board: шаг 7, изображение 2 из 3 MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, AirPort Board: шаг 7, изображение 3 из 3
    • Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  8. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 8, изображение 1 из 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  9. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 9, изображение 1 из 3 MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 9, изображение 2 из 3 MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: шаг 9, изображение 3 из 3
    • Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the logic board.
Заключение
16 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 10/18/12
465 970 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 299 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 24
За последние 30 дней: 79
За всё время: 26,389
