MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement
Выберете то, что вам нужно
  1. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $16.96
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 3, изображение 1 из 2 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 3, изображение 2 из 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Battery Connector: шаг 4, изображение 1 из 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 5, изображение 1 из 2 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 5, изображение 2 из 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 6, изображение 1 из 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Left Speaker: шаг 7, изображение 1 из 2 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Left Speaker: шаг 7, изображение 2 из 2
    • Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
    • Be careful not to damage any surface-mounted components.
  8. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 8, изображение 1 из 1
    • Remove the following screws securing the left speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  9. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 9, изображение 1 из 3 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 9, изображение 2 из 3 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: шаг 9, изображение 3 из 3
    • Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
    • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
Заключение
41 человек успешно провели ремонт по этому руководству.
Sam Goldheart
Участник с: 10/18/12
474 960 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 638 руководств
4 Комментарии к руководству
참조해서 잘따라했어요~ 너무 감사해요^___^
권정철 - Ответить
Youhelpme, ifixit. Done! Thx
Caue Rodergas - Ответить
tnx you for you help ... good job with 30min ifixit
Joeri Van Den Bulck - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 59
За последние 30 дней: 483
За всё время: 26,556
