MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement
Выберете то, что вам нужно
  1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 3, изображение 1 из 2 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 3, изображение 2 из 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Battery Connector: шаг 4, изображение 1 из 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 5, изображение 1 из 2 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 5, изображение 2 из 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 6, изображение 1 из 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: шаг 7, изображение 1 из 3 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: шаг 7, изображение 2 из 3 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: шаг 7, изображение 3 из 3
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • Pull in the direction of the cable, parallel to the logic board. Do not pull up.
  8. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 8, изображение 1 из 2 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 8, изображение 2 из 2
    • Pull the DC-In board connector straight out of its socket on the logic board.
  9. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 9, изображение 1 из 1
    • Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • You may need to gently push the display cable out of the way to expose the screws.
  10. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 10, изображение 1 из 3 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 10, изображение 2 из 3 MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: шаг 10, изображение 3 из 3
    • Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
Заключение
28 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 10/18/12
465 970 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 299 руководств
7 Комментариев
Thanks very much, took me 10 mins, A nice cheap and fast repair for my damaged MagSafe socket
lewismacqueen - Ответить
Thank you for your guidance! Spent $30 on tools as opposed to hundreds and made a simple repair
Brian Smithson - Ответить
Thank you ...just what we need !..
Mark White - Ответить
Did anyone else lose the display to their MacBook Pro mid 2014 after following this repair?
Vance - Ответить
yes I just did and wonder what you did to solve this?
Kaleem -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 10
За последние 30 дней: 87
За всё время: 14,999
