MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement
Выберете то, что вам нужно
  1. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Disable Auto Boot: шаг 1, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Disable Auto Boot: шаг 1, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Disable Auto Boot: шаг 1, изображение 3 из 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Open a gap using a suction cup: шаг 3, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Open a gap using a suction cup: шаг 3, изображение 2 из 2
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  3. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Separate the clips: шаг 4, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Separate the clips: шаг 4, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Separate the clips: шаг 4, изображение 3 из 3
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  4. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 5, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 5, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 5, изображение 3 из 3
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  5. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 6, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 6, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 6, изображение 3 из 3
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  6. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 7, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 7, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 7, изображение 3 из 3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  7. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the lower case: шаг 8, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the lower case: шаг 8, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the lower case: шаг 8, изображение 3 из 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  8. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Uncover the battery connector: шаг 9, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Uncover the battery connector: шаг 9, изображение 2 из 2
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  9. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 10, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 10, изображение 2 из 2
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  10. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 11, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 11, изображение 2 из 2
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
  11. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 12, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 12, изображение 2 из 2
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  12. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 13, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 13, изображение 2 из 2
    • Fold the battery board data cable to the side and out of the way.
  13. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 14, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 14, изображение 2 из 2
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  14. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Disconnect the battery: шаг 15, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Disconnect the battery: шаг 15, изображение 2 из 2
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  15. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Antenna Cable Assembly: шаг 16, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Antenna Cable Assembly: шаг 16, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Antenna Cable Assembly: шаг 16, изображение 3 из 3
    • Remove the four 1.9 mm T3 Torx screws securing the plastic covers on top of the display hinges.
    • Remove both plastic hinge covers.
  16. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 17, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 17, изображение 2 из 2
    • Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
    • Remove the cover.
  17. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 18, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 18, изображение 2 из 2
    • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
    • Remove the cover.
  18. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 19, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 19, изображение 2 из 2
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  19. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 20, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 20, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 20, изображение 3 из 3
    • Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cable connectors.
    • Use a pair of tweezers to remove the two aluminium covers.
  20. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 21, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 21, изображение 2 из 2
    • Remove the four 3.9 mm T5 Torx screws (two from each side) securing the antenna cable assembly.
    • Also remove the twelve 1.1 mm P2 pentalobe screws (six from each side).
  21. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 22, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 22, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 22, изображение 3 из 3
    • Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
    • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  22. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 23, изображение 1 из 1
    • Remove the 2.8 mm T5 Torx screw securing the three antenna coax cables to the main board.
  23. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 24, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 24, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 24, изображение 3 из 3
    • Use an opening pick to lever out the antenna cable assembly in the areas shown.
    • Don't slide the opening pick from side to side, because there are two display cables that can be damaged.
  24. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 25, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 25, изображение 2 из 2
    • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
  25. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement: шаг 26, изображение 1 из 1
    • Remove the antenna cable assembly.
    • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
  26. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Unscrew the display cable assembly: шаг 27, изображение 1 из 1
    • Remove the four 3.9 mm T3 Torx screws securing the two display cable cover springs.
  27. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the display cable assembly: шаг 28, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the display cable assembly: шаг 28, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the display cable assembly: шаг 28, изображение 3 из 3
    • Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the cover spring.
    • Use a pair of tweezers to pull the cover spring of the display cable out of its recess.
    • Repeat this step with the right cover spring of the display cable assembly.
  28. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Open your MacBook: шаг 29, изображение 1 из 1
    • Open your MacBook to a 90-degree angle.
  29. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Set your laptop down: шаг 30, изображение 1 из 1
    • Gently place your laptop keyboard-side-down over the edge of a table so the screen hangs straight down.
  30. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Loosen the hinge screws: шаг 31, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Loosen the hinge screws: шаг 31, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Loosen the hinge screws: шаг 31, изображение 3 из 3
    • Keep your MacBook secured with your free hand while loosening the hinge screws so it doesn't fall off of the table.
    • Loosen, but don't remove, the six T8 Torx screws securing the hinges.
  31. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Fully open the screen: шаг 32, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Fully open the screen: шаг 32, изображение 2 из 2
    • Keep the main body secured against the table and open the screen all the way.
  32. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the hinge screws: шаг 33, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the hinge screws: шаг 33, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the hinge screws: шаг 33, изображение 3 из 3
    • Support the screen with one hand and use your free hand to remove the six T8 Torx screws securing the hinges.
    • Don't let the screen fall on its own as you remove the screws.
  33. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Lower the screen: шаг 34, изображение 1 из 2 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Lower the screen: шаг 34, изображение 2 из 2
    • Lower the screen.
  34. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Free the left hinge: шаг 35, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Free the left hinge: шаг 35, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Free the left hinge: шаг 35, изображение 3 из 3
    • Keep the screen supported constantly during the next two steps.
    • Firmly secure the main body of your MacBook with one hand.
    • With your free hand, push the left side of the screen up and towards the bottom of your laptop to free the left hinge.
    • Be very careful not to damage the Touch Bar connector when moving the left hinge. It can be easily crushed, resulting in an inoperable Touch Bar.
  35. MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the screen: шаг 36, изображение 1 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the screen: шаг 36, изображение 2 из 3 MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement, Remove the screen: шаг 36, изображение 3 из 3
    • Free the right hinge and remove the screen.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
73 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
190 817 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Community
142 членов
Автор 16 232 руководств
29 Комментариев
Will this work for the a1708 model?
Lucas Zhu - Ответить
Hello Lucas Zhu,
the interior build of the A1708 model is a bit different to this one. Especially the connection of the battery. You can check our guides for the A1708 model for the disconnection procedure. The removal of the display in general, is more or less the same with a few differences (e.g. two instead of 3 coax cables). Although the A1708 is a different model you might be able to remove the display following this guide.
Dominik Schnabelrauch -
THANK YOU THANK YOU THANK YOU!! You made my life so much easier. This guide was thorough and definitely made things a lot easier to understand.
Dana Altier-Jeske - Ответить
I disagree with your difficulty level. I found this much harder than a standard display due to the size and number of tiny screws.
mayer - Ответить
Thanks for the guide! I’ve completed mine around 1 1/2 hours while being really careful not to short-circuit any components. Other video that I used for reference: https://youtu.be/153tVLIZVm8 and https://youtu.be/bEDhEWLrkUs
firdaus.abhar - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 52
За последние 7 дней: 307
За последние 30 дней: 1,578
За всё время: 102,773
