Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement
Выберете то, что вам нужно
  1. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement, Disable Auto Boot: шаг 1, изображение 1 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement, Disable Auto Boot: шаг 1, изображение 2 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement, Disable Auto Boot: шаг 1, изображение 3 из 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement, Remove the lower case: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Before you proceed, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Two 5.3 mm screws
    • Two 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 3, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 3, изображение 2 из 2
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight separation between the lower case and the chassis.
  4. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 4, изображение 1 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 4, изображение 2 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 4, изображение 3 из 3
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 5, изображение 1 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 5, изображение 2 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 5, изображение 3 из 3
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 6, изображение 1 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 6, изображение 2 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 6, изображение 3 из 3
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 7, изображение 1 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 7, изображение 2 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 7, изображение 3 из 3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • It may help to pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
  8. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 8, изображение 1 из 1
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  9. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement, Disconnect the battery: шаг 9, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement, Disconnect the battery: шаг 9, изображение 2 из 2
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 10, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 10, изображение 2 из 2
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 11, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 11, изображение 2 из 2
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
    • Locking tabs on ZIF connectors are fragile, so be gentle when using the tip of the spudger.
  12. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 12, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 12, изображение 2 из 2
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  13. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 13, изображение 1 из 1
    • Fold the battery board data cable back and out of the way.
    • If you're replacing your battery, you may need to completely remove and transfer this cable to your new battery. Disconnect both ends and carefully remove the cable. During installation, be careful not to install it upside-down or backwards—note the orientation in the photos.
  14. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 14, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 14, изображение 2 из 2
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 15, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 15, изображение 2 из 2
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket.
    • If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  16. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement, Remove the antenna cable assembly: шаг 16, изображение 1 из 1
    • Remove the four 3.3 mm T3 Torx screws securing the plastic covers on top of the display hinges.
  17. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 17, изображение 1 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 17, изображение 2 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 17, изображение 3 из 3
    • Remove both plastic hinge covers.
  18. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 18, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 18, изображение 2 из 2
    • Remove the two 3.1 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
    • Remove the cover.
  19. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 19, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 19, изображение 2 из 2
    • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
    • Remove the cover.
  20. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 20, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 20, изображение 2 из 2
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  21. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 21, изображение 1 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 21, изображение 2 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 21, изображение 3 из 3
    • Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cable connectors.
    • Use a pair of tweezers to remove the two aluminum covers.
  22. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 22, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 22, изображение 2 из 2
    • Remove the four 3.3 mm T5 Torx screws on both sides, which secure the antenna cable assembly.
    • Also remove the twelve 1.1 mm P2 pentalobe screws on both sides.
    • These small screws can strip easily, so make sure your P2 pentalobe driver is in good condition before applying pressure.
  23. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 23, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 23, изображение 2 из 2
    • Carefully disconnect the two antenna coax cables by prying them straight up from the logic board.
    • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  24. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 24, изображение 1 из 1
    • Remove the 3.4 mm T5 Torx screw securing the two antenna coax cables to the main board.
  25. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 25, изображение 1 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 25, изображение 2 из 3 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 25, изображение 3 из 3
    • Use an opening pick to lever out the antenna cable assembly in the areas shown.
    • Don't slide the opening pick from side to side, because there are two display cables that can be damaged.
  26. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 26, изображение 1 из 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 26, изображение 2 из 2
    • Carefully remove the antenna assembly while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
  27. MacBook Pro 13" Two Thunderbolt Ports 2019 Antenna Cable Assembly Replacement: шаг 27, изображение 1 из 1
    • Remove the antenna cable assembly.
    • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Еще один человек закончил это руководство.
Carsten Frauenheim
Участник с: 03/10/20
112 591 Репутация
Автор 338 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 722 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 21
За последние 30 дней: 96
За всё время: 5,579
