MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement
Выберете то, что вам нужно
  1. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 2, изображение 1 из 2 MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 2, изображение 2 из 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement, Battery Connection: шаг 3, изображение 1 из 2 MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement, Battery Connection: шаг 3, изображение 2 из 2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 4, изображение 1 из 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Assembly: шаг 5, изображение 1 из 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
  6. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 6, изображение 1 из 1
    • Carefully pull the camera cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board. Pulling it upward may damage the logic board or the cable itself.
  7. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 7, изображение 1 из 2 MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 7, изображение 2 из 2
    • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
    • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
  8. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 8, изображение 1 из 2 MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 8, изображение 2 из 2
    • Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
    • De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
  9. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 9, изображение 1 из 2 MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 9, изображение 2 из 2
    • Using the method described in the last step, disconnect the remaining three antenna connectors.
    • De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
  10. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 10, изображение 1 из 1
    • Remove the following five screws:
    • Two 10.3 mm Phillips screws
    • Two 3.1 mm Phillips screws
    • One 5 mm Phillips screw
  11. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 11, изображение 1 из 1
    • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
  12. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 12, изображение 1 из 1
    • Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
  13. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: шаг 13, изображение 1 из 1
    • Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
  14. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 14, изображение 1 из 2 MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 14, изображение 2 из 2
    • Use the tip of a spudger to lift the AirPort/Bluetooth cable connector out of its socket on the AirPort/Bluetooth board.
    • Remove the AirPort/Bluetooth cable.
  15. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 15, изображение 1 из 1
    • Continue peeling the EMI tape off the bottom of the AirPort/Bluetooth bracket and remove it from the assembly.
  16. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 16, изображение 1 из 1
    • Remove the three 3 mm Phillips screws securing the AirPort/Bluetooth board to its bracket.
  17. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement: шаг 17, изображение 1 из 1
    • Remove the AirPort/Bluetooth board from its bracket.
    • Be careful not to damage the pink thermal pad attached to the bracket.
Заключение
94 участников успешно повторили данное руководство.
9 Комментариев
If you change your bluetooth card, its MAC address will change. Since pairing is done by MAC, you will need to re-pair all devices.
Oliver Humpage - Ответить
My Wifi failed, "no hardware found", but the Bluetooth still worked. I replaced the board, but still no dice. Turns out it was the cable. Lesson learned: try the cheaper part first! Not a total loss, now I have Bluetooth 4.
Michael Schwern - Ответить
hi there. Where did you get the cable. I'm looking everywhere, but I only see cables with 3 antenna connectors (but I see 4 connectors on the board) & they all have the isight wire (which i need as well).
Also did you find a good tutorial on how to replace the wire rather than the board?
any help here extremely appreciated!
Joshua Rosen -
Hello,
I was able to complete this repair in less than 40 minutes, thanks to the author and his easy-to-follow guide!
Regarding Step 10 - I found it easier to use a Phillips #000 screwdriver (instead of the recommended #00 size) for the two “orange” 3.1 mm Phillips screws, as it did not slide off the tiny screw heads like the larger-sized screwdriver would.
Robert Sebastian Soyka - Ответить
This is an amazingly succinct and clear at of instructions! My Hat is of to you!
I discovered that the flat wifi cable was not properly plugged in, so I plugged it back in and went no further! Yea it worked!
heartsingingsoul - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 39
За последние 30 дней: 170
За всё время: 122,517
