Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace a noisy or burned-out fan.
Выберете то, что вам нужно
Видео обзор
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use your fingers to pry the lower case away from the body of the MacBook near the vent.
Remove the lower case.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
Remove the following three screws securing the fan to the logic board:
One 7.2 mm T6 Torx screw
Two 5.3 mm T6 Torx screws
Lift the fan out of its recess in the logic board, minding its cable that may get caught.
To reassemble your device, follow these instructions in reverse order. (Always a good idea to first blow the dust out, wipe the inside cover, etc.)
134 участников успешно повторили данное руководство.
11 Комментариев
Hi I did this and now my Mac won't turn on. When connecting the power supply the green light is on but absolutely nothing firing up. No fan no screen nada! HELP!
Reopen the MacBook Pro and disconnect the battery cable, after 30 secs reconnect it.
This solution worked for me.
I broke the plastic fan socket of the logic board, is my computer ruined?
No, But it will need to be repaired by an competent repair person. I charge $100 for this repair.
