Введение
Remove the lower case to access the internal components of your MacBook Pro.
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use your fingers to pry the lower case away from the body of the MacBook near the vent.
Remove the lower case.
57 участников успешно повторили данное руководство.
Комментариев: 2
Has anyone had problems with the screen flickering after assembling the computer again? How can I solve this problem?
Are the inner plugs included with the plug covers? Thank you
