Введение
This guide is an internal private guide used as a prereq.
Запчасти
Детали не указаны.
  1. Remove two Phillips screws securing the hard drive bracket to the upper case.
    • Remove two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  2. Lift the the retaining bracket out of the upper case.
    • Lift the the retaining bracket out of the upper case.
  3. Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
    • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
  4. Remove the hard drive cable by pulling its connector straight away from the hard drive.
    • Remove the hard drive cable by pulling its connector straight away from the hard drive.
Заключение
Еще один человек закончил это руководство.
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 15,171
