Введение
We got our hands on a MacBook Pro 13" Unibody and decided to compare it to a MacBook Unibody -- from the inside! Follow us on Twitter to get all the latest updates as we're doing the teardown!
Выберете то, что вам нужно
This just in: the new MacBook Pro 13" Unibody!
We'll be comparing it to the MacBook Unibody throughout the teardown.
We have a feeling it will be very similar in most regards.
Contents of the box:
User's manual
Restore DVDs
60-watt AC adapter
AC adapter extension cable
Cleaning cloth
No video adapter, as usual.
Some comparisons to the MacBook Unibody:
No access door for the battery on the bottom.
The addition of an SD card slot (and the omission of digital/mic port) is readily apparent.
FireWire is back!
Computer lock is now on the other side.
The SD card sticks out almost .5"! This is a cheeseball design for a MacBook "Pro" if you ask us.
Let's get down to business.
There's no door latch, going along with the "not user-serviceable battery" theme.
We had to dig out a Phillips screwdriver for this step.
A quick flip of the lid and...
...It's almost exactly the same as our old, "lesser" MacBook Unibody.
The battery compartment is identical to the one we uncovered in the MacBook Pro 17" Teardown. We'll venture a guess that it looks the same in the updated 15" Pro as well.
Remove two tri-wing screws and the battery is suddenly replaceable. The sticker comes right off, just as in the 17" Pro -- because it's adhered to just the battery and midwall, not to the optical drive.
7-hour battery specifications:
Model A1322
10.95V
60Wh
"This battery contains no mercury (Hg)."
Although the batteries look similar, they're definitely not interchangeable. The MacBook Pro's battery is too large (and different in shape) to fit into the older MacBook Unibody.
Removing the hard drive...
It's still considered user-replaceable by Apple, but replacement does require removing 10 more screws than on the MacBook Unibody.
First thing we'd do is replace the 160 GB Hitachi with something more meaty.
The optical drive is attached via three Phillips screws.
The brackets and screw layout are identical to the older MacBook Unibody.
Removing the optical drive exposes the right speaker.
It's held in place by adhesive. A quick pry with the spudger will loosen it.
Disconnect the LVDS connector.
Remove 7 motherboard screws.
Remove 2 DC-in screws.
Disconnect trackpad, keyboard, and battery level indicator cables.
Remove LVDS cable retaining bracket.
And the logic board is almost out...
A couple of images of the logic board, before we strip it naked...
Like the MacBook Unibody, the heat sink comes out along with the logic board.
10 Комментариев
Hi. AMAZING walkthrough and I really love your website. I need HELP!
I bought a refurbished MBP 13-inch 2.26 GHz and I don't think it came with a wireless card (I think I got ripped!). Bluetooth is working but my airport says "No Airport card installed".
Anyway - is it possible to check if the wireless card is in there? If not, is it possible to replace it? Any help and advice would be greatly appreciated!!!
The AirPort card is hidden in the display. We don't have a guide specifically for it, but you can follow the display guide to remove the display and then use the clutch cover guide to access the AirPort card (you don't have to remove the front display glass to access the card; the clutch cover guide was part of another guide for the LCD but the steps are generally the same).
great guidelines.... I have a macbook pro mid2009 A1278. buzzing sounds coming out when I play any music. is there any fix?
Hi, I have a macbook pro Mid 2009, now it very slow. can it upgrade? If it must upgrade What I I do for it?
Give me some your opinion, Thank you very much!
Sicerely
Tao Nguyen
nnhattao@yahoo.com
