Введение
Replace the lower case in your MacBook Pro 13" Unibody Mid 2010.
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
41 участников успешно повторили данное руководство.
Комментариев: 3
How do you reattach the little black pads to the bottom of uni-body case?
I thought it was a #000.
