Введение
Replace the subwoofer & right speaker in your MacBook Pro 13" Unibody Mid 2010.
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
  • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
It looks like you need a Phillips #000 screwdriver for the 10 bottom screws. I tried the #00 and it's too big. Good thing I bought a 23 piece precision screwdriver set or else I would have been screwed.
scott523 - Ответить
The 10 screws that hold tha bottom case take a #00 Phillips driver, if yours doesnt fit it's probably because it's cheaply made & not precise enough. The only thing that I needed a #000 driver for was the keyboard screws. They're so small they look like specks of dirt or sand. I stripped out 4 of them & now will need to grind the heads off with a Dremel/rotary tool. The other thing that sucks is iFixit doesn't have a tutorial for keyboard replacement!
iphonetechtips -
A true Phillips head screw's slots are rounded at their inner corners, to allow the screwdriver to "cam out" (pop out) of the screw head before you apply too much torque and strip the threads in the part that you're torqueing the screw into. However, the screws used in the Macbook don't have those rounded inner corners, so they're not Phillips. Instead, they may be a Japanese standard known as JIS B 1012, or a Frearson (also known as a Reed & Prince), but that's a less common design. Maybe technically these non-Phillips screws should be used with a screwdriver that was specifically designed for them, but they can be properly removed and reinstalled using a truly precision-made Phillips #00 (some people find a #000 sometimes works even better) whose tip comes to a sharp point--not the lousy fake "precision" screwdrivers that are sold in too many places. See my next comment for more.
johnsawyercjs -
Many screwdriver manufacturers get away with marketing fake "precision" screwdrivers because, in the words of the Wikipedia article at https://en.wikipedia.org/wiki/List_of_sc...: "Most heads come in a range of sizes, typically distinguished by a number, such as "Phillips #00" or "Torx T5." These sizes do not necessarily describe a particular dimension of the drive shape, but are often arbitrary designations in the same sense as a "Size 8" dress."
In other words, the quality of many "precision" screwdrivers is poor. In my experience, one of the biggest problems with many fake "precision" Phillips screwdrivers is that the four blades at the tip are often too wide, and their width may even vary on the same screwdriver (they're not supposed to). So just because a screwdriver is marketed as a "precision screwdriver", it may not be, and many that are labeled as #00, or even #000, will not work for a Macbook's screws. See my next comment for still more.
johnsawyercjs -
One of the best manufacturers of precision screwdrivers is Wiha (http://www.wihatools.com/tech-tools/prec... cost more, but they're worth it. Or buy screwdrivers from iFixit, who seem to be selling JIS screwdrivers.
Another article with some good info on screw and screwdriver types:
http://www.instructables.com/id/When-a-P...
Also keep in mind that some screws are tougher to remove and reinstall because they have a thread-locking compound on them, which is usually blue.
johnsawyercjs -
Phillips #00 is the correct screwdriver for the lower case. Maybe the one you have is worn or badly made.
David Fear -
Perfect man!Many thanks!:)
wertaerte - Ответить
Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
twisk - Ответить
thanks twisk, I wish i would have read your tip before I finished putting the bottom of my laptop back together. I managed to get all screws in somehow, but one was in fact too-tight.
BTW, big big thanks to the Author: Andrew Bookholt. Just used this guide and my trackpad now works again.
xitxit2 -
i too need a #000 for the bottom of the case -- i got the recommended screwdriver (#00) and unfortunately it's too big
plins718 - Ответить
Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
mastover - Ответить
I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
adlerpe -
That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
joyitsjennie -
Great idea and one I use often
Thomas Overstreet -
Excellent idea! Thanks for sharing it here.
Laura Sharkey -
The colours you used for these circles are indistinguishable for colour-blind people. Please consider using something like the palette suggested by visibone: http://www.visibone.com/colorblind/
Eric Sorenson - Ответить
Squares, Circles, Triangles (you get the idea) would work as well to distinguish the different screws.
danzeitlin -
I'd use a Phillips #000 screwdriver also. The #00 can work, but if the screws are in really tight, it doesn't get far enough down into the screws to get purchase, so it will start to strip (and I agree that the screws are pretty soft). On mine, the screws for the fan were really tight, started to strip with #00, needed a #000 and quite a bit of pressure to get them to move.
jonathanmorgan - Ответить
I thought it took a 000 as well. However, I tried both and realized the 00 works best.
john - Ответить
Hi i was wondering if you can add 16gb to this model? or is 8 the maximum?
Igor - Ответить
The Mid 2010 MacBook Pro 13" does support 16 GB RAM, but it is very picky about the type of RAM. OWC sells a 16 GB kit (2x 8 GB). I think it's got to be 1066 (aka 1067) MHz RAM. A lot of 8 GB modules on the market now are faster than 1066 MHz, and reports I've read say people start getting kernel panics if they use the wrong RAM.
Some info here:
http://www.everymac.com/systems/apple/ma...
"1066 MHz PC3-8500 DDR3 SDRAM"
"*Originally, both the official and actual maximum RAM was 8 GB. However, as confirmed by site sponsor OWC, if running OS X 10.7.5 or higher, updated with the latest EFI, and equipped with proper specification memory modules, this model can support up to 16 GB of RAM."
Our Mid 2010 already had "the latest EFI" (i.e. Boot ROM version in System Profiler), so the reference to updating it may not be relevant.
Winston -
I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
valentinedhdh - Ответить
I had the same problem. The #00 screwdriver worked for some of the screws but some others were too tight and I had to use a #000. Maybe it was because the cover had slightly bent because the battery inside had basically doubled its width, but I still found that the #000 was a much better fit for these screws. Even the ones that came out with the #00 came out much easier with the #000. I would suggest updating this guide to suggest using a #000.
tarriojuan - Ответить
Had no idea they were so expensive.
Franklin - Ответить
Phillips #00 is the right tool for all the steps (Except the 4 HD T6 screws). Maybe there is dirt in the notch.
Luis Soto - Ответить
There is any chance to use the Toshiba MQ01ABD 1 TB 2.5" Internal Hard Drive MQ01ABD100 , it has7200 rpm , shuold it work?
Luis - Ответить
If you are running OS X 10.11.2 or newer, battery provided by iFixIt will not work. I've already tried 2 batteries from iFixIt and neither worked. iFixIt needs to come clean on this unfortunate situation. I've already put 8 hours into this futile effort when it should have taken me 45 minutes.
gkofga - Ответить
What was your solution? I'm using 10.11.3 OS X. I may need a battery replacement very soon too.
John Doe -
<i>The 10 screws that hold that bottom case take a #00 Phillips driver, if yours doesn't fit it's probably because it's cheaply made & not precise enough.</I>
I purchased the IFixIt 54 bit Driver Kit and their Phillips #00 are <b>NOT</b> the appropriate size for the bottom screws on this MacBook Pro. This manual needs to have the tools changed to Phillips #000 Screwdriver. Until then I shall not click the "Give the author +30 points" button. Apart from that, the rest of the manual is very good. It would also be an idea to make a comment about making sure the battery connector is in the correct position when plugging the battery back in. One poster commented that their battery will not charge anymore. My guess is a pin(s) was/were bent due to the connection not being in the vertical orientation when being pressed back together. :-)
THANK YOU for writing and generously supplying this guide for our use. It is much appreciated. +30 point coming when the Phillips #000 size is changed or added.
Joseph King - Ответить
It would be nice to remind fixers which length screws go back in which holes, in case they get mixed up...
Mike - Ответить
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
Mike - Ответить
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
  • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
why is step 3 necessary?
gansodesoya - Ответить
Quote from gansodesoya:
Just to disconnect any power source to avoid damages by short-circuits.
MrKane - Ответить
Removes the possibility of any current flow. This is especially important if you are trying to mitigate the damage to the circuitry due to a spill on a keyboard.
amiller770 - Ответить
I'm thinking of ordering the spudger. I was thinking of order the heavy duty spudger... or should I just order the normal. Will either of the spudgers work for this DIY?
shockaaa - Ответить
Once you have a set of spudgers, you will wonder how you ever went without them. :-)
Brian -
$@$@. Don't use an non-isolated screwdriver for this. I just shorted-out my battery :(
Lukas Besch - Ответить
You are absolutely right, never use a screwdriver on the logic board or any connector! Delicate use of fingernails or a credit card will get you through most situations if you lack a spudger.
Logan Bean -
How do you get that battery connector back on? Do you just press it in back in place after you're done?
Horace Chung - Ответить
yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
maccentric -
Would it not be advisable to drain the battery completely before attempting to repair, if you want to be sure you don't get a spark when removing the battery connector?
Berlugana
bduault - Ответить
Disconnecting the battery connector is not that different from simply unplugging a battery from an older model MacBook with a removable battery. You're not trying to protect yourself from a "spark", but the internal circuitry when taking the MacBook apart.
amiller770 -
I neglected step 3 and now my computer won't turn on. Could I have shorted out my logic board?
Plamen - Ответить
I had the same problem , my macbook doesn't switch on working
marioluiggi -
A very easy and fast update indeed! Using this guide and the tools indicated on top I replaced the two RAM cards (2GB each) with two 8GB RAM cards from OWC for a total of 16GB RAM in my MBP Middle 2010 Core 2 Duo (Officially not supported according to Apple).
Make sure you select RAM with these specs: 16GB DDR3 PC8500 1066MHz Kit (8GBx2)
Apps open much faster and I can run a virtual machine at a decent speed.
Removing the battery is not required, but in some instances can make installing ram much easier. If you plan on upgrading from 4GB (2X 2GB) to 8GB (2X 4GB) Removing the battery would be better. There are two levels of ram. If you are replacing both levels, then remove the battery. If you are just replacing the top, dont bother. Removing the battery for very long or even at all (depending on the CMOS battery age and health) could possibly reset settings, the clock, saved wifi passwords, and more.
Everett Whiteman - Ответить
It is beneficial to remove the battery at this stage.
Knox Karima - Ответить
This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
Jeff Diamond - Ответить
Guys I just used my index finger nail. It’s the most useful nail to let grow a little bit for this type of procedure. Came off pretty easy when using both my right hand index and left hand index together to lift the plug up out. Found some plastic folded it and place it right over the socket so the plug would go back in and now the plug holds the plastic in place so I can focus on the main work.
clsmithj - Ответить
  • For precautionary purposes, we advise that you disconnect the subwoofer connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Remove the soft padding that may be on top and gently pull the connector up out of its socket on the logic board.
During this step, I accidentally ripped out the whole subwoofer connector from the logic board.. I tried taping it back with scotch tape, but it didn't work - my right speaker and subwoofer don't work anymore.. what are my options? Solder it back on?
Archdelux - Ответить
It is not necessary to remove the camera cable connector (step 5) or the camera cable connector (step 10). Simply push the camera cable gently aside to remove one of the three screws securing the optical drive (step 11). Gently wiggle the optical drive from under the camera cable connector and go to step 12. Less chance of ruining your motherboard!
tomhart - Ответить
It does indeed come out of the connector, but the picture makes it hard to see how; the connector it goes into sits on top of the board—however, I, too, ripped mine off the board trying to remove it; I only got it out of the clip after I tore it off. SIMPLY DONT; it's unnecessary. I plan to solder it back if one of my Robotics club friends lets me borrow a soldering iron.
Rachel - Ответить
I avoided disconnecting the camera cable. If you are careful, it's not needed. I've taken tons of PC's apart and its 1 million times more complicated than a mid 2010 MBP! I've had my MBP for 5 years and I'm now upgrading memory, adding a SSD for OS and 750gb in the optical drive for storage. My computer has just started getting slower. This couldn't be any easier to do!
amp1069 - Ответить
Same problem: The speaker/subwoofer connector was removed, and now it can’t be connected again. Probably has to be soldered, but the points are so tiny that this seems hardly possible. Result: No more bass and right speaker. Avoid.
Michael - Ответить
Same story, on the picture the person broke it… You can see the naked soldering pads… This is wrong! Anf if you think glue or tape should fix it, you should not be attempting this!
Albert - Ответить
  • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
  • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
  • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
I just completed this replacement and there is no need to do this step, you can work around this cable pretty easily. Obviously you need to be careful "dancing" around it. But it's perfectly feasible and you don't risk to break stuff disconnecting it.
Massimo C - Ответить
I messed around with my MBP some years ago and everything was fine. When I opened it yesterday that plastic retainer was glued *above* the camera cable and wasn't very sticky anymore.
On a whim I decided to not put it back in. Now there's now Wifi anymore (did all the hardware reset things, nothing). Can that small plastic thing have to do anything with the wifi?
Thanks for you help!
Nick Names - Ответить
Well, I put that plastic thing back in, still no Wifi (would have really surprised me ^__^).
Nick Names -
I'm having a similar problem where I think I messed something with this step and now my computer is REALLY slow and I cant get any wifi. Heres my story.
I am going to put a SSD in place of my HDD so I also took the optical drive out of my mac to reduce the weight. If this matters I also changed the fan because that was broken. I'm wondering what the problem could be. One thing im confused by in the guide was step 5. Am I supposed to remove that connector? If so how do I do that? I may have wiggled that a little trying to take it out.
My computer will boot up very slowly but the mouse and keystrokles lag by about 4-5 seconds. The computer won't connect to wifi. The battery symbol has an "x" inside the battery so I keep in plugged in. It also has my apps in the dock and my name in the upper right hand corner.
Any ideas what is wrong? If something is wrong how do I clone my old data onto my new hard drive? If you have any questions about my situation ill gladly answer them.
Billy Walsh - Ответить
HDD in DVD slot with caddy works, but seems VERY slow, logically i assume step 5 , is HIGH risk critical, and now I must try undo everything , cos I spent a lot of time in step 5 and probably kill my mac
Roman Nicolaevich - Ответить
This is the stage (5) that concerns me with my lack of wifi and Bluetooth. I enlarged the iPad screen to max so I could view the clear plastic cable retainer. Leaving the screen on max I missed the part that said,"pull the camer cable connector towards the Optical drive to disconnect from the logic board" makes me wonder if that caused the problem,as I lifted it away from the logic board? Any I found it very difficult to align the connector with its socket. Any thoughts please.
Peter Mayo - Ответить
Which of the four ribbon connectors relates or controls the WiFi Bluetooth and Camera ?
  • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
I did on my 15" MBP (putting a SSD) without any problem
but I did it on this very model 13" on a friend MBP
and it seems the optical drive cable is dead (both drives works connected elsewhere ) the only other part i was not able to test separately is the data doubler from OWC that allows to fit a SSF in place of the optical drive.
Do anybody experience this ?
The optical drive cable shows no sign of tearing i unplugged it very carefully
BUT once disconnected during the optical drive extraction from its original location the cable might have touch the logical board (not sure just guessing)
Any clues welcome !!
Chewbee - Ответить
  • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
Добавить комментарий
  • Remove the following screws securing the subwoofer to the upper case:
    • One 3.8 mm Phillips screw.
    • One 5 mm Phillips screw
On my computer, the 3.8 mm screw was near the midpoint of the subwoofer (left-to-right in the photo) and near the bottom. The 5 mm screw was top right of the subwoofer.
BobG - Ответить
  • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
  • Lift the subwoofer off the optical drive, and set it above the computer.
  • Remove the two 10 mm Phillips screws securing the camera cable bracket to the upper case.
  • The leftmost screw may remain captive in the camera cable.
  • Lift the camera cable bracket out of the upper case.
  • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
  • Lift the optical drive from its right edge and pull it out of the computer.
  • Peel back the small piece of black tape covering the right speaker cable.
  • Be careful, as the power button ribbon cable is directly under this piece of tape.
  • Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
I recommend you to use for this step an opening tool instead the spudger. The jimmy is a good option
Toni - Ответить
  • Lift the subwoofer and right speaker assembly out of the upper case.
Заключение
31 участников успешно повторили данное руководство.
Комментариев: 2
p.S. NVRAM resert does not workSo i did this multiple times and my new subwoofer still does not output low frequencies, most likely a hardware issue. Anyone have any ideas as to how to fix it?
dragng8 - Ответить
excellent review, really helped a lot, and i only had one left screw left lol :)
jamieexeter - Ответить
Просмотр статистики:
За 24 часа: 20
За 7 дней: 67
За 30 дней: 333
За всё время: 37,461
