Отремонтируйте ваше устройство
Обучение ремонту
Магазин
  1. Выкрутите 10 выделенных шурупов:
    • Выкрутите 10 выделенных шурупов:
    • Три 14.4 mm Phillips #00 шурупа
    • Три 3.5 mm Phillips #00 шурупа
    • Четыре 3.5 mm Phillips #00 шурупа с бортиками
  2. Этот шаг не переведен. Помогите перевести
    Use your fingers to pry the lower case away from the body of the MacBook near the vent. Remove the lower case.
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. Этот шаг не переведен. Помогите перевести
    Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board. It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. Этот шаг не переведен. Помогите перевести
    Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. Этот шаг не переведен. Помогите перевести
    Remove the following two screws:
    • Remove the following two screws:
    • One 5.6 mm Tri-point screw
    • One 13 mm Tri-point screw
  6. Этот шаг не переведен. Помогите перевести
    Carefully peel the battery warning label off the upper case between the battery and the optical drive.
    • Carefully peel the battery warning label off the upper case between the battery and the optical drive.
    • Do not remove the label from the battery.
  7. Этот шаг не переведен. Помогите перевести
    Use the attached plastic pull tab to remove the battery from the upper case.
    • Use the attached plastic pull tab to remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Финишная черта
677 участников успешно повторили данное руководство.
Andrew Optimus Goldheart
Участник с: 17.10.2009
470 408 Репутация
Автор 410 руководств
Команда
iFixit Участник iFixit
Community
134 членов
Автор 15 565 руководств
Комментариев: 33
I thought these batteries couldn't be replaced.
brucebridges - Ответить
These batteries are built to the same spec as OEM (Apple)
They are just not "user friendly" to replace like most devices are, the price we pay for pretty devices.
This guide is excellent and now I know I need 1 more tool before I do this myself. I need that tri-wing screwdriver.
John Lang -
Anyone know of any batteries with a larger capacity that could fit this?
Anrothan - Ответить
It seems that there are no true larger capacity batteries for this Macbook. Ones that claim higher capacity are usually of dubious quality.
coffee -
Clear, well written instructions, thank you! (But yes, a line about take off shoes and socks and ground yourself is helpful. )
unlvkatherine - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 106
За последние 7 дней: 730
За последние 30 дней: 3,890
За всё время: 524,570
