Введение
Use this guide to replace a broken display assembly.
Запчасти
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use your fingers to pry the lower case away from the body of the MacBook near the vent.
Remove the lower case.
Bonjour, alors cela va dépendre du modèle de MacBook Pro Retina concerné. Par exemple, si vous avez un 13 pouces, allez consulter cette page MacBook Pro 13" Retina Display Repair et sélectionnez-y votre modèle. Les Retina 15 pouces se trouvent ici MacBook Pro 15" Retina Display Repair. Sinon cet outil https://fr.ifixit.com/info/ID-your-Mac (pour l’instant seulement disponible en anglais) vous aide à identifier quel modèle vous avez et vous redirige vers la page de votre appareil, où vous trouverez le tutoriel correspondant à votre Retina. Bonne réparation !
Merhaba, trackpad değişimi ve ayarlaması için tornavidaya ihtiyacım var, bu konuda yardımcı olabilir misiniz acaba? Ne tür bir tornavidaya ihtiyacım var ve nereden bulabilirim acaba?
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
yes - as with disassembly of any electronic component you have to remove any power source. You don't want to accidentally turn the Mac on
khull -
Sooo the track pad is under the battery...you kind of have to remove it to get to the track pad.
This step is not really required. Apple does not recommend it.
My Battery does not get recognized after i disconnected it, screw this site!
Did you properly ground yourself to the case before putting the spudger to the connector/logic board? Did you use a spudger or something else that is non conductive...or did you use a flat blade metal screw driver instead and compound your error by not grounding yourself before touching the logic board? All kinds of variables here but the bottom line is iFixit provided you a guide to fix your computer. Lots of others have followed this guide without trouble. Your battery issues are not their fault. They did say this guide was moderate difficulty...maybe it's just a little beyond your skill level. We should all know our limits!
Don't know what the deal is with the battery, but this IS a necessary step to keep from frying the logic Board if you accidentally touch something and short it out. I did this step every time during my troubleshooting and The battery was ALWAYS recognized by the system the next time I turned the MBP on. So be safe and don't fry your logic board in the process...
Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
Installed/upgraded 4gb RAM to the system maximum 16gb and installed a 500 gb SSD today....DID NOT disconnect the battery cable....no issues at all when I powered back up. Then did a clean install of OSX Yosemite....next I used a time machine backup to put all my stuff back on the new HD. From start to finish it took about 4 hours. Macbook boots up right at 16 seconds now.
Easiest to use two spudgers, one on each short end, I found.
Its a lot easier and safer (corner wise) to pry it using the flat side of the black spudger directly in front of the connector (don't go/use the corners) very easily you will be able to pry it further by inserting the spudger into a better and thicker plastic section of the connector
DON'T remove the Battery Cable, you risk the battery NOT being recognised when you start the Mac up again, or breaking it!! More to the point, APPLE DOES NOT RECOMMEND THIS, so don't do it! I Installed 2x 8GB ( 16Gb total) of Crucial Mac RAM at 1333Mhz for my Late 2011 MacBook Pro, and it works beautifully, fully recognised and working well. I followed these instructions, but as Apple didnt recommend disconnecting the battery, I skipped this step, and as well as taking less time, nothing was damaged or broken, and everything works perfectly!!! Just make sure that you DISCHARGE ALL STATIC ELECTRICITY FROM YOUR HANDS, by touching a metal surface in the Mac. Apple recommends the edge of the Optical Disk Drive ( Big silver thing ) before touching any parts. Also, Take care removing the RAM out of its packet, DO NOT touch the Gold connectors, and hold the RAM by the edges. Finally, be PATIENT, GENTLE and it should all go perfectly. I managed it first time, with no technical ability, so follow my advice. Good luck!
Switch off your Mac and continue without disconnecting the battery. Don't know how it will switch on by itself.
This comment made me think that disconnecting the battery was no point at all, because really - how would the computer be able to switch on by it self. So... I had my mac flipped around and was fiddling with the last part of the guide when I all of a sudden hear the start up sound! Don't know how and why it did. I turned it around with it guts open and guts hanging out. Screen was on. I forced it to shut down by keeping the power button down. Turned it back and first thing removed the battery cord.
Luckily the computer started up just like normal. But hearing that sound was just too scary.
BTW I had been cautious to de static myself multiple times.
wassberg -
Definitely do this step. It's an easy disconnect anyway and also easy to reconnect later.
I removed the battery cable for the repair. When I plugged in the MagSafe adapter after the repair, the Mac turned on automatically without pressing the power button and I was a bit worried, but after a restart everything worked fine again. I did have to reset date and time in Preferences. The battery was recognized OK.
Okey, I skipped this battery disconnection part. Did not do anything like this before in my life, changing the cable was super easy!
The official Apple guide to replacing the RAM says nothing about disconnecting the battery but it does recommend touching metal inside to discharge static. https://support.apple.com/en-us/HT201165
I always do this when working on MacBooks (over ten years) and it never caused an issue. Don’t worry about this step as removal of the battery connector is simple. This particular connector is pretty much goof-proof as it won’t break. I’m fairly aggressive and just pop it off whenever I’m working on the Macbook Pro.
I have a late 2011 MacBook Pro 13in and did not disconnect the power from the battery. I upgraded from 4gb to 16gb and worked perfectly. Just make sure to power it down and be gentle. It was super easy and quick, and I feel a significant boost in performance. Cant wait to install my 1TB SSD Samsung 860 next!
Be patient on disconnecting this one. It worked for me step by step, little by little.
u can use 16GB DDR3 @ 1600mhz. intel says 16 @ 1333, and apple 8.
apple will solder even the folders to the background for to sell you the “open” or “move to the trash” command. if the battery is not removable, its not a casuality…. u can be sure
Would draining the battery (by using the machine until it runs out of power) do the trick for this? Seems it would be less risky than potentially damaging the connector/cable during disconnection for example.
Cannot install any os on new ssd ? Mac is reading it.. please help
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
What are the changes of it broke when i bend it?, after i disconect it does not work anymore
The guide worked perfectly, as it has in the past (our family has three Mid-2012 Macbook Pros that have been separately upgraded with RAM and SSD).
The PH00 screwdriver fit perfectly.
One note on getting the screws to seat easily and thread perfectly...always turn them gently a couple turns to the left (CCW or Anti-Clockwise) until you hear a small click. That's where the threads will grab. Works with any screw, but when threads are fine, this will help ensure that the screw is at the correct angle and will grab and seat perfectly.
Great guides. Thanks!
Got RAM in but only one slot is working and now I can't remove! The RAM won't pop up like before and tabs don't seem to do anything. Please advise.
I put some tape between the connector and socket while working on the drive.
That's a good tip
Anrothan -
One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
does the battery connection need to be removed? I only ask as other videos etc have not shown this step.
Très bonnes explications. Concernant le débranchement de la batterie, faute de “smudger”, on peut le faire tout doucement avec le bout des ongles (s’ils ne sont pas coupés trop à ras, LOL), et surtout ne pas tenter de le faire d’un coup: il faut y aller tiers de mm par tiers de mm. Le retrait des anciennes mémoires n’est pas facile non plus, car on a très peu de place pour manœuvrer, là encore il faut y aller petit à petit, avec les plus grandes précautions! La barrette située le plus profond doit être soulevée assez fortement dans sa partie libre pour pouvoir être extraite de son étroite cuvette et ce n’est pas simple. Le remontage est nettement plus simple que le démontage. Il faut surtout faire très attention à ne pas confondre les petites vis à épaulement avec celles qui n’en ont pas. Je conseille, avant de remettre le couvercle de fond du Mac, de faire un essai de redémarrage pendant une minute ou deux pour bien voir si tout est OK.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
N.B! Thank you very much all you here on iFixit! Some IMPORTANT notes. Be very careful BEFORE prying the connectors up and down. They are very fragile and the picture could actually be seen as showing a bending loading in their weakest direction, AROUND its slender axis. The connector is slender and inserted on the logic board, so the gentle "walking" up and down should be done ALONG their slender direction and WITHOUT touching the adjacent connectors. If bending is done around its axis the soldering comes apart and the cable is done and gone. Just happened. These flat cables are one of the weakest design spots in my experience. They are a major time, money and geist consuming reason for malfunction like Wi-Fi connection problems, HDD, SSD not found internally but externally from USB issues et al being found on different forums. Thanks again and again.
Carefully pull the camera cable out of its socket on the logic board.
I ripped the camera cable where can I buy a new one
Be very careful at step 6!
I had the same problem with the model "Late 2011" and I doubt to step 6 because the camera cabel connector was plugged very tight in the board-socket. So I cannot believe it is so easy to unplug the connector.
I bought a new camera cable on eBay.
I ripped the camrea cable socket on the logic board.
Walk the cable out with a spudger!!! The Retina 2012 guide has this and this was so easy using the tool.
do you know the color order
I didn’t even bother pulling out this camera cable, just moved it aside and kept it out of the way.
Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
What adhesive is suitable for reattaching the foam tape and wires that were removed from their normal routing?
I want to know that too!
Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
Can someone explain me what this "antenna cable" is for? I changed my Topcase and this antenna did break during the procedure =(.
The problem is i can't find this cable anywhere to buy and i don't even know his function. WIFI and Bluetooth are working just fine.
Can someone please help me?
Same here, I was removing the display and once i put it back on the three little antenna cables fall off. Any idea how to replace it or find it?
Those are the WiFi antennae..
auadix -
When I was repairing the hinge of my laptop two of the antenna cable connectors came off the ends of the antenna wires. Can someone confirm what these are called and the size so I can source replacements? I believe they may be called ’Micro RF Coax Connector’ but I am not sure what size I need. For the record the wifi is actually still working but may be a bit slower than normal. Thanks for your help.
Using the method described in the last step, disconnect the remaining three antenna connectors.
De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
What are these? Like in order? I broke the middle one and am trying to find a replacement. The mac actually functions quite normally, currently using it to type this ahaha, anyways, only difference I've noticed is that the speaker sounds a bit weird/off. Internet is fine, display is fine, everything is fine at the moment besides the speaker. And in case you're wondering how exactly broken it is, its not connected to begin with since it ripped ahahaa...
Same issue here, with the first from the top. I wonder if i will have some kind of issue in future.
I found re-attaching these antennae connectors the trickiest bit by far as they appear very delicate and seating them correctly was fiddly. In the end lighting them from the side with a small torch helped to check their position before gently pushing them down. The first one made a clicking sound as it connected, the other two went on silently. MBP wifi working perfectly now. I’m fairly sure that was at least £100 of labour had I taken it in for repair so thanks ifixit for saving me money and for the warm glow of accomplishment!
Where can i buy that very same set of antennas, I’ve broken what seems to be the bluetooth one, even tough my Mac was already used when i bought it,(and that cable did not seem to came from the same spot has the other 3 “small ones”) the screen wobbled a Little bit so there i tried to fix it myself, now i have no wobble, but no Bluetooth though :(
Remove the following five screws:
Two 10.3 mm Phillips screws
Two 3.1 mm Phillips screws
One 5 mm Phillips screw
The two screws marked in orange are not present in my early 2011 macbook pro
Should be worth noting that the black tape/wire grommet on the right red screw is flimsy. When overtightened, it can tear.
Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
Muss der Antennenkontakt in der Gehäuseecke mit dem Rahmen verlötet sein? Bei mir ist diese Verbindung sehr locker
Remove two of the three 6 mm T8 Torx screws securing the right side of the display to the upper case.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
This was the hardest part for me. It took me a bit to figure out what parts were the socket and which was the cable and where were they going to separate. What I did was gently twist the pull tab on the cable in a clockwise direction. This allowed me to see a small separation between the socket and cable. At that point I knew what side of the pull tab I had to use a little pressure on, to continue to wiggle the cable free.
I disconnected and when i connect it back the screen doesn turn on
Remove the following two screws:
One 8.6 mm Phillips screw
One 5.5 mm Phillips screw
Remove the display data cable retainer from the upper case.
When putting the display case back together, I found it MUCH easier to reinsert the display cable before screwing back in the data cable retainer. It did require me angling my screwdriver to get the rightmost screw in, but it was not too difficult. It certainly made it much easier to reinsert the display cable since I had more freedom to maneuver it back into position. Hope this help others. God Bless!
Remove the piece of foam tape covering the display screws near the MagSafe DC-In board.
Remove two of the three 6 mm T8 Torx screws securing the left side of the display to the upper case.
Open your MacBook Pro so the display is perpendicular to the upper case.
Place your opened MacBook Pro on a table as pictured.
While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
Remove the last remaining T8 Torx screw securing the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
I used this guide to tighten the hinges; screen was all wobbly because the four screws that hold the screen in place had worked themselves loose. Surprised that getting at the screws required the full removal of the display. One thing that's helpful in putting it all together is in regard to adjusting the position of the hinges; with the screws loose, there is a lot of play in the hinges, and if you just torque them down, the lid won't fit right. I snugged up the screws then put the display back in place on the body & inserted one screw into each side, then loosened the hinge screws to align the screen. That has to happen before replacing the black plastic cover over the bottom edge of the display.
My Macbook Pro developed a severe wobble in the display so I took it in to the Genius bar to see what could be done. They told me that fixing it would involve replacing the whole display because the problem is due to a piece of plastic inside breaking off. I suspected it just needed to have the hinge screws tightened so I brought my laptop home and gave it a go using this guide. Well, it turns out I was right! The Torx screws joining the hinges to the the display had come loose at both sides. To fix this, I got the hinges lined up straight on the display and tightened them down. To attatch the hinges to the body, I tightened one screw on each side half way and closed the display to line it up with the body. I then proceeded then to tighten all of the Torx screws on the body. Thank you for the great guide, Philip! I love this site!
Have anyone got a didd Saad play disappearing and coming back on
the issue started when connected with a non apple HDMI cable
Might be a dumb question but can I swap screens from a broken MacBook Pro to the my working one (both same model)
Yes, you can
When separating the display, be crazy careful with those tiny WiFi antenna wires you undid in step 9. One of mine came apart with almost no force whatsoever. If you do break one, reroute them when reassembling so that ports J0 and J2 on the Airport card have good connections. That’ll retain your laptop’s ability to connect to 5GHz WiFi if you’re unable to replace the entire antenna assembly.
207 участников успешно повторили данное руководство.
Комментариев: 36
No the connector in the logic board/video cable is slightly different.
I have a mid 2012 13" Macbook pro. This is a non retina computer but would it be possible to change it to a Retina Display using this guide and would my Mac recognize the new screen?
(I have plenty of memory and the graphic card can definitely handle it too)
Thanks
I doubt it would work, But be my guest to try it. (and post a guide on how to do it)
Did you ever try swapping for a retina? Very Curious!
yes
Does this include the aluminum backing, not just the LCD?
Yeah! I did it. I had to use two different guides todo thelcd screen.but my MacBook is clear and no giant black crack. The mid 2012 "glass". Is plastic...just saying.
Can you give us a link to the two other guides?
Hi Albert,
Can you please, finish your toughts? Have you any success with changing the low-res display with retina or hi-res? Talking about mac book pro 13" mid2012.
I would appreciate very much if you post where you find the display and which one!
Your link doesn't work anymore. What was it about? Did you manage to install a higher resolution display on this model?
David -
My replacement display for this fix came with the display in a closed folded position, any suggestions for rotating the display clutches on the newly purchased screen so that I can manage to work it into place?
Stick a screwdriver through the holes in the mounting brackets to give you enough leverage to twist them when the screen is removed.
Does anybody know the model number of the display? I am trying to drive one as an external display.
Can the Display Glass be changed? I have a mid 2012 unibody MacBook Pro with broken Glass, the display is OK.
I have the same issue, wondering if this is a possibility.
Technically the screen should work: both are driven via LVDS connector that look identical, both use the intel 4000 graphics chip.
However, the hinges screw position are in different positions. So, unless someone finds a way to fit the mid-2012 hinges onto the late-2012 screen assembly, then the next step would be to manually dismantle the screens and graft the late-2012 matrix inside the mid-2012 enclosure. Great to try if you have a few hundred bucks to burn.
Hi, thanks for the awesome tutorial. Is it possible to replace a mid 2012 13’’ Macbook pro screen with the screen of a 2010 13’’ Macbook pro?
Thanks!
My girlfriend just bought a 2012 macbook pro and the little plastic on the bottom seems to pop out of place slightly and it’s a little annoying does anyone know a fix for this seems simple but i don’t wanna touch the computer till i’m sure
If you’re referring to the plastic bezel on the bottom of the display, the bezel is attached to the display assembly so if it is loose you’ll likely need to pop the display off the main chassis and reseat the bezel. You may be able to reseat the bezel without doing this but it will be a lot easier to fix it if you take the display out. Just follow the guide on replacing the display and then once you have the display removed you have better access to the bezel and can then lock it in better. If you need help reseating it just look online for info on reinstalling the bezel on the display.
Just wanted to say thanks! Bought a display assembly from you kind folks and had my mac up in running in less than an hour!
Works Perfectly Thanks Andrew! Your Awesome, and to all the guys at fix it you guys rock
An easy-to-follow, pretty much stress-free repair guide! With the step-by-step breakdown, I can pause for lunch if I want to, then get back to my repair at the correct step. Thank you SO much, AOG❣️
The screens from MacBook Pro 13 mid 2012 and 2011 are COMPATIBLE 100%, I already did replacement - you need to open up just a little bit the females’s connector by the sides - 0.01mm (or something). I put 2011 screen on 2012 logic board. Write me for fotos, if interested.
I’m curious. I am having a “double image” issue on my 2012 MacBook Pro 13” (unibody). Would replacing the display solve this issue?
Double image: There is an exact copy of whatever is on the screen appearing just below the “real” image. A ghost, or shadow image if you will. When I connect an external monitor to the laptop no double image is seen upon the external monitor, but still is prevalent on the MacBook screen.
I would probably first check to make sure the cable that’s connecting your Macbook display to the main board is seated properly before exploring the expensive display replacement. You may be just looking at a faulty connection between the board and the display. Worst case scenario, the connector itself on the main board is damaged in some way resulting in the bad connection. Which would be an expensive replacement. If the cable on the display itself is damaged, you’ll need a whole new display. But determining any of this is going to require testing on your part. I’d also consider the possibility the display panel itself is damaged as well.
I took my screen off my macbook to tighten the hinges because it became loose. After I reassembled and turned on the machine, the screen no longer works. One mistake I made during disassembly was not disconnecting the power cable and I accidentally hit the power button while working on the machine. I don’t know if that has anything to do with it.
hello guys, i have an issue with my wifi on my mac mid 2012 just losing connections. Even if i try and connect again, it will not even let me try to connect. I turned it in to have it serviced but they couldnt find out were the issue came from. I think it comes from the neck or hinges of my mac. At curtain angles, after a longer period of time, it will lose the wifi. But i adjusted the screen a bit, and then i didnt lose it anymore. It might be a coincidence but i dont think it is..has anyone been across this issue before? PS i have changed out my wifi/bluetooth card
Hi
I have a MacBook Pro 13-Inch "Core i5" 2.5 Mid-2012 Specs.
Recently I changed my default HDD to the SDD and also replaced one of the default 2GB rams with an 8GB ram. (now the system totally have 10GB )
after turning up the laptop I saw some light which known as “stage light”.
Also, I tried to reconnect the LVDS cable, which is located between the fan and the edged of the body, however, “stage lights” are still there
Gracias, realíce el cambio de la batería y me quedo increíble, gracias
anywhere suggestions where to buy replacement screen (model A1278) in EU?
Does void the warranty?
jfondeur - Ответить
No, it does not void the warranty. More specifically: http://eshop.macsales.com/Search/display...
oakdragon12 - Ответить
How much weight can I save by removing the optical drive?
gunes314 - Ответить
You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
Marshall WahlstromHelgren -
Also wondering how much weight I'd save by just removing. My drive is broken for ages, but I have not needed it in ages. The HD was already replaced by a cheap SSD (second best thing after upgrading to 8GB), so I'd appreciate losing some weight. I mean, the computer. Although I could lose some too... erm... well, anyway, I guess the lack of the DVD would not interfere with anything, right? Opinions?
Carlos Duarte do Nascimento - Ответить
Apple has meticulously balanced the MacBook's weight from left to right, and removing the optical drive may off-balance the Mac.
Seji the veggie -
What so you think that a removing the optical drive which weighs less than a AA battery will unbalance a MBP making it unusable? LOL!
Unless you use the MBP on a high wire (an even then I have my doubts) you'd never notice the weight difference.
pmhparis -
The issue is not one of weight but an issue with the systems cooling and an opening which objects could enter. For a few grams of weight I don’t think its worth it! A better solution would be to swap out the heaver HD for a much lighter SSD, and getting all of the performance benefits of the faster drive as well!
While you might not think it the optical drive also acts as a stiffener so there is less twist in the case. This is because of the size of the hole for the DVD/CD’s so taking it out weakens the case design.
Dan -
I'm thinking you'd probably be OK losing the DVD drive without a problem. Just make sure the optical drive cable is secured or you might hear it rattling in there from time-to-time.
John Adam Wickliffe - Ответить
Hey guys,
this website is amazing. I read it to guide me on fixing my mac book pro, but on the video, the girl gives a wrong information.. She says that is not possible replace just the keyboard... But I managed to replace only my keyboard. It is boring because I have to remove approximately 70 screws but it is possible. Thanks a lot! You guys helped me save about US$300 thats because in Brazil some technicians would charge me with that amount!
I posted some pictures on your facebook page..
renatumb - Ответить
Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
Robert Wacker - Ответить
Great tutorial. I found that using a Phillips #0 in lieu of the #00 worked much better.
kschmesk - Ответить
Totally agree!! I used the #00 screwhead for 7 out of the 10, but for the remaining tricky ones I used the #0 screwhead and it helped me out. I was so worried I would strip the tiny screw, but this comment saved me!
Juliana Mak -
I tried the PH #00 for the 10 screws that hold the bottom case and it's too big, instead PH #000 works perfectly. Are you sure this screws are #00?
Alex - Ответить
The likely problem with your wifi is not the card but the antenna leads that go into the plastic clutch
. Ifixit don't have a guide to change this as it it includes the isight camera so the screen has to be disassembled which is fairly hard
I got round it by using the camera cable from the old set and cutting off the new one
brian whittle - Ответить
Hello MacWorld,
Just want to say that this site is a great resource for repairing or upgrading your Mac. I had a bad SATA cable in my MacBook Pro and after ordering a new one from the "IFIXIT" site I received the cable within two days, replaced it and was up and running again in no time. Thanks IFIXIT for you help!
wer 10/5/15
tayseer999 - Ответить
I have found that my MacBook Pro 13 Late 2011 has five shouldered screws and not four. I am not sure exactly where it goes but I have put it in the top left corner of the picture as it is the odd one out.
ForumHermit - Ответить
Hello, where can I buy the screws I need in case I lose one of them?
taylornya - Ответить
iFixit sells a kit: MacBook Pro Unibody Lower Case Screw Set
Darrell Johnson -
on my device the #00 screwdriver was a bit too small. a #0 was the perfect one
Maximilian Klotz - Ответить
I found with mine that the shouldered and un-shouldered screws were reversed (the three un-shouldered screws going where the orange colour indicates). Also, I found that the front four screws went in at an angle.
gilded yak - Ответить
Are you sure the short screws are different? The set sold here just says “Seven 3 mm Phillips #00 screws.”
Jack - Ответить
I have the same question. What is the difference between shouldered and not? So hard to see any difference…
Michael Wilkens -
I’ll second that. I could never find them being different.
otetz -
Same here… I could not notice hte difference. Anyone at iFix would like to comment?
LDS -
I have one stripped screw... How opening without drill it?! Any suggestions please?
rodrigosady - Ответить
I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
Michael Wilkens -
I used 3 eggcups to hold the screws ;>) They are very fiddly and easy to drop on floor so keep the MacBook away from the edge of the surface you are using to avoid accidentally dropping a screw off the edge of a table, etc.
Stephen Smith - Ответить
A screw does not come out, how can I get it out? Many thanks in advance for your help
Wilder Torres - Ответить
Since you’ll be removing many screws it’s best to plan ahead. I found it especially helpful to have a small plastic tray with about a dozen separate compartments to hold screws. As I removed screws I kept them in one compartment for each item removed. For example: The lower case removal involves the removal of ten screws. I kept them all in the first tray compartment and set the lid aside. Also, I put a post-it note identifying this compartment as “Lower case” and noted that the top right-most screws were the long ones. I continued with this methodology as a removed the next item, and the next, etc. Disassembly notes included for each compartment. This helped SIGNIFICANTLY as I was able to reassemble the Macbook easily by simply going from one compartment to the next (in reverse order). This guide is rated “Difficult” which it really isn’t when you plan ahead in this way. It saves time in the long run.
airshack - Ответить
when putting the macbook pro back together, the middle screw on the right side (if the computer is upside down and you have the hinge furthest away from you) requires a bracket that was not included with my new upper case. i had to remove it from my old case and transfer it over - if you don’t do this, that screw will have nothing to attach to.
this was one of the many additional parts i needed to transfer from my old case to the new one that aren’t mentioned in this guide…i’m adding comments on each step to try to help others…i wish i had thought to take pictures.
Matt - Ответить
It seems to me the yellow and orange screws are the same
Luca Giancarli - Ответить
If you look closely, the four front screws (with the yellow circles) have a short unthreaded section under the head. The orange keyed screws are threaded all the way up.
Raymond Ives -
The screws used on all Retina models, as well as about everything Apple has made since the iPhone 4, uses “PENTALOBULAR” not Phillips screws. These look like a TORX driver, but it has 5 concave sides. I believe the size you want is a P4 or T4. (1.2mm).
Don Cely - Ответить
Two screw types:
______________________________
Shouldered Unshouldered
xxxxxxx……….xxxxxxx
..xxxxx……..….…….x…….
…..x……..…...……….x…….
…..x…………....……..x…….
El Crashitan - Ответить
If you are following this guide to upgrade to a better drive and want to keep your system and data intact I highly recommend first following the guide to Clone an Existing Drive using the recommended free SuperDuper!. That process was a breeze and gives you confidence that the new drive will come up looking exactly the way it did when you started.
Patrick Langvardt - Ответить
My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
jeremyyoung - Ответить
I did this last weekend, and definitely, a Phillips #000 screwdriver is required (not a Phillips #00!)
Javier Campos Delgado - Ответить
WIll this card be good with MacBookPro 17 inch 2011
Zafar Ali - Ответить
I just followed this guide and it really helped me install a replacement cable and a new Samsung 860 EVO 500gb SSD in my aging MacBook Pro 13 A1278 MID 2012. It’s performing like a new machine now! The guide worked fine, but I’m curious why this HD cable costs €45 on Ifixit’s webshop, and only €13 on Amazon.de (I live in Europe)? The Amazon purchase also included two screwdrivers and a spudger.
Jeff Baker - Ответить
I found out that one way to reduce the chance to loose screws is to leave them in their holes of the lower case right after unscrewing them. In fact, you can put the lower case back in place with all but one screws in place. The only one that I ever needed to put apart was the long one at the top right in the picture (the one that goes close to the display data cable underneath the lower case). Hope this help others! and you stop wondering about shouldered versus not shouldered short (3.5mm) ones :-)
LDS - Ответить
For a MBP 2011, I’m not able to unscrew one of the 14.4 mm in the lower back. Can I know how can I get that done?. Thank you..
Rajesh Rajasekharan - Ответить
very nice '''artical keep it up'''
fxxxman - Ответить
