Введение
Display connection issues? Use this guide to replace a faulty display data cable rather than replacing the entire display.
Выберете то, что вам нужно
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Remove the following 6 screws:
Two 10 mm T6 Torx screws on either side of the RAM slot.
Four 14.5 mm Phillips screws along the hinge.
Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Remove the upper case.
Disconnect the three antenna cables attached to the Airport Extreme card.
Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
Disconnect the inverter cable from the logic board by placing a spudger beneath the cable and lifting up.
Remove the silver T6 Torx securing the ground loop in the display data cable to the casing.
Support the display with one hand while removing the following 3 screws:
Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
Grasp the display assembly on both sides and lift it up and out of the computer.
Remove the two 5 mm Phillips screws from the lower left and right corners of the display (two screws total).
Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
Rotate your spudger toward the rear bezel to separate it from the front bezel.
If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
Lift the rear bezel by its bottom edge and rotate it away from the display assembly to separate the top edge.
Remove the rear display bezel from the display assembly.
Disconnect the LCD backlight from the inverter by pulling its connector away from the inverter board.
Disconnect the inverter cable by pulling its connector away from the socket on the inverter.
Remove the pieces of yellow kapton tape from the bottom left corner of the display.
Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
Remove the piece of tape securing the camera cable to the LCD.
Remove the pieces of tape covering the display data cable and camera cable connectors.
Carefully peel the camera cable off the foam tape along the top edge of the LCD.
Gently pull the camera cable away from its socket on the camera board.
Pull the display data cable connector away from its socket on the LCD.
Pull both cables parallel to the face of the logic board.
If you have a Core Duo machine, refer to picture 1 and remove three Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
If you have a Core 2 Duo Model A1211 machine, refer to picture 2 and remove two Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
Remove the small Phillips screw from behind the display data cable.
Remove the small rectangular steel bracket by sliding it away from the right clutch hinge.
Remove three Phillips screws attaching the clutch assembly to the lower edge of the front display bezel.
Push the open edge of the clutch cover away from the left clutch hinge to pop it off the clips attaching the two parts.
Remove the clutch assembly from the front display bezel.
De-route the display data cable from around the right clutch hinge and remove it from the front bezel.
4 участников успешно повторили данное руководство.
