Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Accessing the RAM is easy.
Выберете то, что вам нужно
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
97 участников успешно повторили данное руководство.
