MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement
Выберете то, что вам нужно
  1. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Battery: шаг 1, изображение 1 из 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, RAM Shield: шаг 2, изображение 1 из 1
    • Remove the three identical Phillips screws from the memory door.
  3. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 3, изображение 1 из 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Upper Case: шаг 4, изображение 1 из 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 5, изображение 1 из 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 6, изображение 1 из 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 7, изображение 1 из 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 8, изображение 1 из 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 9, изображение 1 из 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 10, изображение 1 из 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Optical Drive: шаг 11, изображение 1 из 1
    • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  12. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 12, изображение 1 из 1
    • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
  13. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 13, изображение 1 из 1
    • Lift the optical drive up and out of the computer.
  14. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Logic Board: шаг 14, изображение 1 из 1
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  15. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 15, изображение 1 из 1
    • Disconnect the iSight and display data cables from the logic board by sliding the cables out of their connectors, removing tape as necessary.
  16. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 16, изображение 1 из 1
    • Disconnect the eight indicated connectors by placing a spudger beneath each cable and lifting up.
  17. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 17, изображение 1 из 1
    • Remove the silver T6 Torx screw securing the ground loop in the display data cable to the casing.
  18. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 18, изображение 1 из 1
    • Remove the single T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
    • Lift the clear plastic shield off the right ambient light sensor.
  19. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 19, изображение 1 из 1
    • Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
  20. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 20, изображение 1 из 1
    • Remove the following 15 screws:
    • One 4.4 mm black Phillips screw to the right of the ram slot.
    • Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
    • One 6.2 mm black T6 Torx screw on the right side of the left fan.
    • Five 9.4 mm silver T6 Torx screws securing the left and right fans.
  21. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 21, изображение 1 из 1
    • Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
    • Place the fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
  22. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 22, изображение 1 из 1
    • Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
    • Remove the right fan from the computer.
  23. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 23, изображение 1 из 1
    • Lift up the left side of the logic board and disconnect the gray and black power cable from the bottom of the board.
  24. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 24, изображение 1 из 1
    • Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
    • To properly reassemble your MacBook Pro, you'll have to clean off and replace the old thermal compound. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
  25. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Speakers: шаг 25, изображение 1 из 1
    • Lift the heat sink out of the computer.
  26. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 26, изображение 1 из 1
    • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
    • Remove the left fan from the computer.
  27. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 27, изображение 1 из 1
    • Disconnect the three antenna cables attached to the Airport Extreme card.
    • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
  28. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 28, изображение 1 из 1
    • Deroute the Airport antenna cables from their channel in the left speaker.
  29. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 29, изображение 1 из 1
    • Remove the single black T6 Torx screw located just above the Airport Extreme card.
    • Lift the small silver metal retaining bracket up and out of the computer.
  30. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 30, изображение 1 из 1
    • Lift the Airport Extreme card up and slide it out of its connector.
  31. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 31, изображение 1 из 1
    • Peel up the orange hard drive cable from above the ExpressCard cage.
  32. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 32, изображение 1 из 1
    • Disconnect the speaker cable from the corner of the left I/O board.
  33. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 33, изображение 1 из 1
    • Carefully peel up the black adhesive tape securing the speaker cable along the rear edge of the lower case.
  34. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 34, изображение 1 из 1
    • Continue to free the speaker cable from the black tape until it is free from all three sections of tape.
  35. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 35, изображение 1 из 1
    • Remove the single black T6 Torx screw securing the right speaker to the lower case.
  36. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 36, изображение 1 из 1
    • Use a spudger to pry up the right speaker from the lower case.
    • Remove the speakers from the computer.
  37. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 37, изображение 1 из 1
    • Remove the single silver Phillips screw securing the clear plastic shield over the left ambient light sensor.
    • Lift the clear plastic shield off the left ambient light sensor.
  38. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: шаг 38, изображение 1 из 1
    • Use a spudger to pry the left ambient light sensor board out of its housing on the left speaker.
    • Speakers remain.
Заключение
6 участников успешно повторили данное руководство.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 12,210
