MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment
Выберете то, что вам нужно
  1. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment, Battery: шаг 1, изображение 1 из 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment, RAM Shield: шаг 2, изображение 1 из 1
    • Remove the three identical Phillips screws from the memory door.
  3. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 3, изображение 1 из 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment, Upper Case: шаг 4, изображение 1 из 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 5, изображение 1 из 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 6, изображение 1 из 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 7, изображение 1 из 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 8, изображение 1 из 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 9, изображение 1 из 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 10, изображение 1 из 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment, Upper Case Cable Replacment: шаг 11, изображение 1 из 1
    • Use a spudger to pry up the translucent plastic sheath covering the keyboard connector.
  12. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 12, изображение 1 из 1
    • Use the tip of a spudger to flip up the black plastic flaps locking down the keyboard and keyboard backlight ribbon cables.
  13. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 13, изображение 1 из 1
    • Slide the orange keyboard backlight ribbon out of its connector.
  14. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 14, изображение 1 из 1
    • Peel up the orange tape covering the keyboard backlight connector.
  15. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 15, изображение 1 из 1
    • Use the tip of a spudger to flip up the brown plastic flap locking down the keyboard backlight ribbon cable.
  16. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 16, изображение 1 из 1
    • Use a spudger or your finger to slide the keyboard backlight ribbon out of its connector.
  17. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment: шаг 17, изображение 1 из 1
    • Disconnect the power button cable, the bluetooth cable, and the sleep sensor cable.
    • Carefully peel up the orange ribbon cable removing tape as necessary.
Заключение
7 участников успешно повторили данное руководство.
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 19
За всё время: 9,580
