MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement
Выберете то, что вам нужно
  1. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement, Battery: шаг 1, изображение 1 из 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Before beginning, I found some small plastic bags and labeled each of the with the location the screws would come from once removed and the appropriate step number. Once the screws were removed I placed them in the labeled bags and did not have to worry about mixing screws up. Also, provided a good way to insure that no steps were skipped in the reverse process
    rpbetancourt - Ответить
    If you don't have any plastic bags, you can always print out the photos in black and white as you go, and then tape the screws on to the print outs over the circles that denote the screw positions in the photos. This method helps get every single screw back in it's exact location, even months after a tear down. ;o)
    Adam - Ответить
    Thank you very much!
    Evgeniy - Ответить
    When I did this, I used a empty egg carton to store my screws. I wrote the steps where I removed screens in Sharpie on the bottom of the "egg cup" and then dropped the screws in as I went. Then I just worked backwards to put it all back together.
    mark93 - Ответить
    I Generally just use a piece of paper with a rough sketch of the system and locations of the screws with prestik.
    Tarn Alcock - Ответить
  2. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement, Memory Door: шаг 2, изображение 1 из 1
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
  3. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 3, изображение 1 из 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement, Upper Case: шаг 4, изображение 1 из 1
    • Remove the two Phillips screws in the battery compartment near the latch.
    Getting these screws in and out is difficult because most screwdrivers are longer then the battery compartment is deep and so will be slightly off plumb. When you go to re-assemble the computer, getting these screws to seat is one of the hardest parts of the re-assembly. It's very important to be gentle and not to strip the threads.The screw should tighten and come to a stop after 3-4 turns. If you turn 6 or more turns and don't feel it grab, then back off and try again, making sure that everything is in alignment.It might be easier to start with the left screw, because it is further away from the latch mechanism.
    dalphotography - Ответить
  5. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 5, изображение 1 из 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
    A T6 worked but was too small. A T7 was better.
    nrpardee - Ответить
  6. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 6, изображение 1 из 1
    • Remove the four Phillips screws on the port side of the computer.
    Be careful when reassembling your laptop -- do not put the screw into the DVI port! It will not come out.
    Scott Rose - Ответить
    Been there, done that!
    I honestly don't remember how did I ultimately succeeded in getting that %#*@ screw back from the hole...
    maxime.abbey -
    by Scott Rose Jan 4 @ 11:12 PM
    To keep this from possibly happening, I placed 2 pieces of tape over the DVI connector pin holes.
    Be careful in step 4, these two screws are shorter than the four screws in step 6, dont mix them up!
    brendantully1 - Ответить
    If you still have the DVI to VGA adapter that came with the computer plug it in to the plug and screw it tight, that way you will not put one of the screws into the holes.
    netdude21 - Ответить
  7. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 7, изображение 1 из 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 8, изображение 1 из 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 9, изображение 1 из 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
    • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
    there are 2 push buttons inside the harddrive bay which release the front of the upper case.
    mforgie - Ответить
    this is an annoyingly difficult step. it is VERY hard to get the front part off without bending the unit improperly. Would be great to know where the two "push buttons" are.
    lessig - Ответить
    On my MacBook, there were no pushbuttons. Rather, two mini phillips screws were holding the case on inside the battery bay. The two screws are under two ball-bearing-like nubs that help hold the battery in the bay.
    khank - Ответить
    I just realized these were the screws mentioned in Step 4, which I missed originally. Did you miss step 4 too?
    khank - Ответить
    I discovered that I didn't need to take the case off completely. I just propped it up with a small screwdriver and was able to remove the airport card and replace it with a new one fairly easily.
    schemedream - Ответить
    That's not so difficult step. you shoul know , that front edge of upper case holding only on 5 plastic "locks" 4 in front edge upon the superdrive, 5-th near the "sleep light, open laptop button"
    just lift up the rear edges of upper case to 35-40 degrees
    Hofmann78rus - Ответить
    [I d just say carefule on the prising open - these are fragile screw tab fixings joined to the uppercase. - Patience and gentle pressure and all works fine .
    daithid - Ответить
    Getting the top case off, especially right above the optical drive slot was a @#$%^. !^$%. Was finally able to work it loose by twisting in the budger. Be careful.
    Archhawk - Ответить
    the two push pins are in the battery area behind the front of the open button
    mykeylynx - Ответить
    I agree! It was really very difficult just ROCKING the front panel. NOT done! Do not pry it from the front of the unit, as the soft metal edge gets scratched! I turned the unit upside down and slowly pried the keyboard apart left-to-right from INSIDE the Battery Bay, slipping a plastic pen to keep it apart. When I finally looked at what was holding it down, it was these 5 grey&black plastic SNAP slots, and 4 of them were behind the DVD slot.
    http://www.facebook.com/photo.php?pid=40...
    Mario da Silva - Ответить
    I found I had to push with a little force from underneath the battery compartment where the touch pad is located to free the bottom edge of the case. The case came away with two loud snaps. At first I thought I'd broken something, but then it appeared that it was just the plastic above the slot loading super drive that was held in very tightly and needed some encouragement.
    Joshua May - Ответить
    There are several clips along the front of the case in front of trackpad and above the optical drive slot. These need to be gently levered open (eg using an old credit card), and clipped closed on reassembly. Start at the left hand side. Take care not to bend the aluminum top. When reassembling, check the top panel for kinks/bends and straighten by hand before reassembly.
    cheongi - Ответить
    The way I did it was to lift the back to about 45% (the ribbon cable is long enough) and then used the spudger to force the 4 snap tabs in front of the optical drive to separate, working from the right edge towards the middle (they will 'pop'), ending with the last tab to the left of the sleep light.
    Hilal Malawi - Ответить
    After reading all the step 9 comments I was prepared for it to be very difficult. The two bendable tabs on the left front of the case were no bigger than 1/4 inch wide each and caused no trouble taking it off or putting it back on. Lifting the cover off happened before I knew it. I was carefully lifting the cover from side to side and 'poof' it was off and the yellow ribbon attaching between the case and the keyboard was so old and brittle it parted ways without my permission so that took care of step 10 right there but no problem.
    Being prepared, reading the guide, printing the guide, taping each screw to the right place on the guide made it all easy. I'm amazed it went so smooth on the first run-through. Thanks iFixit!
    Sally - Ответить
  10. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 10, изображение 1 из 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
    not necessary. just attach a string around both the screen and the keyboard. it will stay in a steady position..
    -urdus.
    urdus - Ответить
    I found that the ribbon connecting the top part of the case to the logic board wasn't long enough and the connector did have to be disconnected.
    Joshua May -
    -urdus.
    Excellent tip! Thanks, this allowed me to skip steps 10 and 11 (any unnecessary tinkering with the logic board is recommended).
  11. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement, Display Assembly: шаг 11, изображение 1 из 1
    • Disconnect the two antenna cables attached to the Airport Extreme card.
    • The white antenna cable connects to the left side of the Airport Extreme card.
  12. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 12, изображение 1 из 1
    • Deroute the Airport antenna cables from their channel in the left speaker.
    These were hard for me to get back on.
    mowzer11surf - Ответить
  13. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 13, изображение 1 из 1
    • Disconnect the iSight, inverter, and left fan cables from the logic board by gently pulling in the direction of each cable.
    The ISight inverter did now want to come out. The grey cloth on top pulled off.
  14. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 14, изображение 1 из 1
    • Disconnect the display data cable from the logic board.
  15. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 15, изображение 1 из 1
    • Remove the silver T6 Torx screw securing the ground loop on the display data cable to the casing.
    this screw won’t come out!? Any suggestions? Please advise.
    fafel1 - Ответить
  16. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 16, изображение 1 из 1
    • Support the display with one hand while removing the following 3 screws:
    • Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
    • One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
  17. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 17, изображение 1 из 1
    • Grasp the display assembly on both sides and lift it up and out of the computer.
  18. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement, Rear Display Bezel: шаг 18, изображение 1 из 2 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement, Rear Display Bezel: шаг 18, изображение 2 из 2
    • Remove the two 5 mm Phillips screws from the lower left and right corners of the display (two screws total).
    The screw fixing points on my MBP came away from the back case. They are spot welded to the back case and in the Photo's I have you can see the point's each. You may think that if this happens you lose the ability to use the screws to secure the enclosure but you still can use the screws if you position the fixing points before clipping the front panel in place. Have a needle of small nail to align though the holes before replacing the screws. This is not easy and you need to be practices at this sort of repair.
    They sit under the plastic surround and do! add the the string of the completed enclosure.
    substevew - Ответить
  19. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 19, изображение 1 из 3 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 19, изображение 2 из 3 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 19, изображение 3 из 3
    • Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
    • Do not insert your spudger between the plastic strip and the rear bezel.
    • With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
    • Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
  20. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 20, изображение 1 из 3 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 20, изображение 2 из 3 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 20, изображение 3 из 3
    • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
  21. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 21, изображение 1 из 3 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 21, изображение 2 из 3 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 21, изображение 3 из 3
    • Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
    • Rotate your spudger toward the rear bezel to separate it from the front bezel.
    • If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
  22. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 22, изображение 1 из 1
    • Lift the rear bezel by its bottom edge and rotate it away from the display assembly to separate the top edge.
    • Remove the rear display bezel from the display assembly.
  23. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement, LCD Panel: шаг 23, изображение 1 из 3 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement, LCD Panel: шаг 23, изображение 2 из 3 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement, LCD Panel: шаг 23, изображение 3 из 3
    • Remove the pieces of yellow kapton tape from the bottom left corner of the display.
    • Remove the pieces of tape securing the display data cable and camera cable to the display.
    • Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
    • The adhesive connecting these straps to the display is very strong. An edged tool is helpful to separate the adhesive while you peel the straps off.
    • Remove the piece of tape securing the camera cable to the LCD.
    these 'green' tapes are orange in my mbp
    Jon May - Ответить
    mine also. Does anyone know the function of these? They're called ground straps here, so I would guess they should have good contact, but how do you get them to adhere again? I replaced my inverter but the screen is still dark. I think worse than before, since before, it would blink and sometimes work for an instant. I'm going to go back in and check my connectors and such, but was trying to gather more info. Any thoughts to share anyone?
    David Muniz -
  24. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 24, изображение 1 из 1
    • Carefully peel the camera cable off the foam tape along the top edge of the LCD.
  25. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 25, изображение 1 из 1
    • Use the tip of a spudger and carefully flip the ZIF connector bar up to release the before the camera cable.
    • Gently pull the camera cable away from its socket on the camera board.
    • Pull the cable parallel to the face of the LCD.
  26. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 26, изображение 1 из 1
    • Pull the display data cable connector away from its socket on the LCD.
    • Pull the connector parallel to the face of the LCD.
  27. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 27, изображение 1 из 2 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 27, изображение 2 из 2
    • Remove the four black Phillips screws along the left and right edges of the display (eight screws total).
  28. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 28, изображение 1 из 1
    • The next few steps will require you to separate the LCD from the adhesive applied to the upper and lower edges of the front bezel. A heat gun may be helpful to soften the adhesive to prevent damaging the LCD panel during removal.
    • The adhesive is applied such that it sticks to a thin steel strip around the perimeter of the LCD. When prying your LCD away from the front panel, be sure you are separating the front panel from the steel strip on the LCD.
    • Use the flat end of a spudger to gently lift one of the top corners of the LCD out of the front bezel.
    I needed to use heat gun to remove lcd from bezel.
    2nfinite - Ответить
    Same here, needed a heat gun. P.S. Harbor Freight had them on sale cheap (tip, not advertisement).
    Michael Lance -
    This is easy if you use the small lugholes on the left and right sides near the top edge (which cover philips screws) to insert a spudger or fine slotted screwdriver and then work along the top with another spudger as if you were using tyre levers on a bicycle tyre. when you get to the middle, repeat from the other side.
    Jon May - Ответить
  29. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 29, изображение 1 из 1
    • Work your way along the top edge of the LCD, slowly prying the attached steel strip away from the front bezel.
    Push the spunger gradually along the gap between screen and rear bezel. Dont use a back and forth motion to prize them apart, as is suggested in earlier steps. I initially tried using a back and forth motion to prize them apart which slightly bent the rear bezel.
    rupertshanks - Ответить
  30. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 30, изображение 1 из 2 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 30, изображение 2 из 2
    • Now that the top edge is free, slightly lift the LCD out of the front bezel for enough room to pry the steel strip along the lower edge of the LCD away from the front bezel.
    • Pry along the lower edge of the LCD until it is freed from the adhesive on the front bezel.
    Prying with plastic spudger at the lower edge of the display housing bent the aluminum frame for me. Suggestion: if you don't plan on keeping the old glass, pry it away from the aluminum slowly (opposite direction than shown in step 33).
    Michael Lance - Ответить
  31. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 31, изображение 1 из 2 MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 31, изображение 2 из 2
    • Lift the inverter out of the clutch cover.
    • Disconnect the LCD backlight connector from its socket on the inverter board.
  32. MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement: шаг 32, изображение 1 из 1
    • Lift the LCD out of the front bezel, minding any cables that may get caught.
    I finally finished this, it took a few hours. After I finally got the LCD separated from the bezel, I got the replacement screen out of the box ready to install and I couldn't believe I had been sent the wrong part (NOT ORDERED FROM THIS WEBSITE!!). Anyway I thought I would put everything back together until the correct part arrived...I turned the computer on and the screen was fixed...no new part required. Now I am thinking that maybe the screen wasn't stuffed but maybe a connector was loose.......anyway these instructions were a godsend and next time i am ordering my part from here.
    rlgriffo - Ответить
Заключение
29 участников успешно повторили данное руководство.
4 Комментариев
Be aware that replacing the rear bezel without problems depends entirely on gentle handling. There are some aluminum tabs in recesses on the top edge of the rear bezel that do not take kindly to rough handling!
dave - Ответить
You would be well advised to buy in some Kapton tape before reassembly, as the old tape tends to split on removal.
dave - Ответить
Bravo. Worked like a champ. Excellent write up and really appreciate it. I did it twice today hahahah
Timothy Allen - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 32
За всё время: 39,986
