Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical Phillips screws from the memory door.
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Remove the two Phillips screws in the battery compartment near the latch.
Remove the following 6 screws:
Two 10 mm T6 Torx screws on either side of the RAM slot.
Four 14.5 mm Phillips screws along the hinge.
Remove the four Phillips screws on the port side of the computer.
Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Remove the upper case.
Disconnect the iSight, inverter, and left fan cables from the logic board.
Use a spudger to flip up the brown plastic flap securing the left ambient light sensor cable to the logic board.
Slide the left ambient light sensor cable to the left and out of its connector.
Peel up the left ambient light sensor cable from above the left fan.
Peel up the iSight and inverter cables from above the left fan, removing tape as necessary.
Remove the following 3 screws:
One 6.2 mm black T6 Torx screw from the right side of the fan.
Two 9.4 mm silver T6 Torx screws from the left side of the fan.
Lift the lift fan up and carefully peel up the tape securing the fan to the heat sink as you go.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Disconnect the two antenna cables attached to the Airport Extreme card.
Remove the single silver Phillips screw located just above the Airport Extreme card.
Lift the small silver metal retaining bracket up and out of the computer.
Peel back the orange tape on the right side of the Airport Extreme card.
Lift the Airport Extreme card up and slide it out of its connector.
Peel up the orange hard drive cable from above the ExpressCard cage.
Disconnect the speaker cable from the corner of the left I/O board.
Remove the single black T6 Torx screw securing the left speaker.
Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
Disconnect the large multi-colored power cable from the left I/O board.
Remove the following 5 screws/standoffs:
Four black T6 Torx screws securing the left I/O board to the lower case.
One 4 mm standoff located between the audio jacks.
Lift up the right side of the left I/O board and slide it out of the computer.
Remove the following 4 screws:
Three 1.2 mm silver Phillips with large heads.
One 3.2 mm black Phillips on the left side.
Disconnect the short left I/O board cable.
Left I/O board remains.
19 участников успешно повторили данное руководство.
2 Комментариев
Just curious what the short cable's purpose is? I have a Macbook this model and the battery is not charging. Before I go down the path of changing out the whole board is it worth replacing just this cable?
