Введение
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
Запчасти
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Remove the two Phillips screws in the battery compartment near the latch.
Remove the following 6 screws:
Two 10 mm T6 Torx screws on either side of the RAM slot.
Four 14.5 mm Phillips screws along the hinge.
Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Remove the upper case.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Remove the following 3 screws:
Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
One 4.8 mm black Phillips screw at the top right corner of the drive.
The 4.8mm screw may be a T6 Torx
Disconnect the PRAM battery cable from the bottom right corner of the logic board.
Use a spudger to pry up the PRAM battery from the lower case.
Lift the PRAM battery out of the computer.
9 участников успешно повторили данное руководство.
