Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide contains instructions for using the old-style iFixit adhesive remover with separate bottle and syringe, which is no longer sold. For the updated version, click here.
Use this guide to safely remove the glued-in battery from your MacBook Pro with the help of an iFixit battery replacement kit. The adhesive remover in your kit will dissolve the adhesive securing the battery, allowing you to remove it with ease.
iFixit adhesive remover is highly flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
For your safety, drain your MacBook Pro's battery before you begin this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured.
Note: The solvent used to dissolve the battery adhesive will damage your speakers if it comes in contact with the plastic speaker enclosures. This guide instructs you to remove the speakers before proceeding to the battery.
  1. Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. Peel back the warning label covering the battery connector.
    • Peel back the warning label covering the battery connector.
  4. Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board. Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
  6. Use the tip of a spudger to push the camera cable connector toward the fan and out of its socket on the logic board.
    • Use the tip of a spudger to push the camera cable connector toward the fan and out of its socket on the logic board.
    • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the connector out of its socket. Do not pry up, or you will damage the socket.
  7. Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan. Slide the spudger underneath the length of the cover, releasing the adhesive. Lift the cover and flip it back so that you can access the cables underneath.
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
  8. Use your fingers to pull the AirPort/Camera cables up off the fan. The cables are adhered to the fan, so peel them up carefully to avoid damaging them. Carefully de-route the cables from the plastic cable guide.
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
  9. Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.  On reassembly, connect this end first as it does not flex. In a similar fashion, remove the I/O Board connector from its socket on the I/O Board. Remove the I/O Board cable from the MacBook Pro.
    • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board. On reassembly, connect this end first as it does not flex.
    • In a similar fashion, remove the I/O Board connector from its socket on the I/O Board.
    • Remove the I/O Board cable from the MacBook Pro.
  10. Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
    • Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
  11. Grasp the thin sides of the AirPort card and pull parallel to the logic board, removing the AirPort card from the MacBook Pro. Grasp the thin sides of the AirPort card and pull parallel to the logic board, removing the AirPort card from the MacBook Pro.
    • Grasp the thin sides of the AirPort card and pull parallel to the logic board, removing the AirPort card from the MacBook Pro.
  12. Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board.
  13. Remove the following three screws securing the right fan to the logic board:
    • Remove the following three screws securing the right fan to the logic board:
    • One 4.4 mm T5 Torx screw
    • One 3.9 mm T5 Wide Head Torx screw
    • One 5.0 mm T5 Torx screw with 2 mm collar
  14. Lift and remove the right fan out from the MacBook Pro.
    • Lift and remove the right fan out from the MacBook Pro.
    • When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
  15. Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
    • Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
  16. Remove the following three screws securing the left fan to the logic board:
    • Remove the following three screws securing the left fan to the logic board:
    • One 5.0 mm T5 Torx screw with 2 mm collar.
  17. Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
    • Lift the left fan out of the device.
  18. Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
  19. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  20. Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board. Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
  21. Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer. Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  22. Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board. Carefully lift the I/O board and remove it from the lower case.
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • Carefully lift the I/O board and remove it from the lower case.
  23. Use the flat end of a spudger to pry the headphone jack connector up from its socket on the logic board.
    • Use the flat end of a spudger to pry the headphone jack connector up from its socket on the logic board.
  24. Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board. Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
    • Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
    • Be sure to pry on the cable head, and not on the socket itself. Prying on the socket may cause it to separate from the logic board.
  25. Peel back any tape covering the keyboard ribbon cable connector.
    • Peel back any tape covering the keyboard ribbon cable connector.
  26. Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Pry only under the hinged retaining flap, not the socket itself, or you may break it off the board. Use the flat end of a spudger to gently back the keyboard ribbon cable out of its socket by pushing first at one side, then the other.
    • Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pry only under the hinged retaining flap, not the socket itself, or you may break it off the board.
    • Use the flat end of a spudger to gently back the keyboard ribbon cable out of its socket by pushing first at one side, then the other.
  27. Use the flat end of a spudger to pry the trackpad ribbon cable connector up from its socket on the logic board.
    • Use the flat end of a spudger to pry the trackpad ribbon cable connector up from its socket on the logic board.
  28. Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
    • Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
  29. Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Pull the microphone ribbon cable out of its socket.
  30. Use the tip of a spudger to pry the display data cable lock and rotate it toward the DC-In side of the computer. Pull the display data cable straight out of its socket on the logic board.
    • Use the tip of a spudger to pry the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  31. Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near to the MagSafe 2 connector.
    • Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near to the MagSafe 2 connector.
  32. Remove the following six screws securing the logic board to to the upper case:
    • Remove the following six screws securing the logic board to to the upper case:
    • One 2.6 mm T5 Torx screw
    • Two 5.8 mm T5 Torx screws
    • One 3.8 mm T5 Torx screw
    • One 5.2 mm Raised Head T5 Torx screw
    • One 3.5 mm Silver T5 Torx screw
  33. Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro. Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board. When reinstalling the logic board, check the cables at the marked locations to make sure they don't get pinned underneath the logic board.
    • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
    • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
    • When reinstalling the logic board, check the cables at the marked locations to make sure they don't get pinned underneath the logic board.
    • Clockwise from top: keyboard, trackpad, battery, right speaker, keyboard backlight, display, microphone, headphone jack, left speaker.
  34. Remove the logic board assembly from the MacBook Pro.
    • Remove the logic board assembly from the MacBook Pro.
  35. Remove the following three screws securing the left speaker to the upper case: One 5.6 mm T5 Torx screw
    • Remove the following three screws securing the left speaker to the upper case:
    • One 5.6 mm T5 Torx screw
    • One 6.9 mm T5 Torx screw
    • Lift the left speaker out of the upper case and set it aside.
  36. Remove the following three screws securing the right speaker to the upper case: One 5.6 mm T5 Torx screw
    • Remove the following three screws securing the right speaker to the upper case:
    • Remove the right speaker from the MacBook Pro.
  37. Remove the two 3.9 mm T5 Torx screws securing the battery board.
    • Remove the two 3.9 mm T5 Torx screws securing the battery board.
  38. The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
  39. With the front edge of the MacBook Pro facing you, lift the right side and prop it up at a slight angle, using a sturdy foam block or book. In the following steps, you'll apply liquid adhesive remover to the right (outer) edge of the battery. Keeping this side of the MacBook Pro elevated will help the adhesive remover flow underneath the battery.
    • With the front edge of the MacBook Pro facing you, lift the right side and prop it up at a slight angle, using a sturdy foam block or book.
    • In the following steps, you'll apply liquid adhesive remover to the right (outer) edge of the battery. Keeping this side of the MacBook Pro elevated will help the adhesive remover flow underneath the battery.
  40. Now that your MacBook Pro is fully prepped, it's time to prep yourself. iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  41. Open your container of adhesive remover. Fill the syringe included in your kit with a small amount (approximately 1-2 milliliters) of adhesive remover.
    • Open your container of adhesive remover.
    • Fill the syringe included in your kit with a small amount (approximately 1-2 milliliters) of adhesive remover.
    • It's best to fill the syringe with no more than about 1-2 milliliters of adhesive remover at a time, so as to avoid accidentally applying too much.
    • Refill your syringe as needed throughout the rest of this procedure.
  42. Apply a small amount of adhesive remover (approximately 1 ml) evenly along the elevated edge of the outer right battery cell. Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    • Apply a small amount of adhesive remover (approximately 1 ml) evenly along the elevated edge of the outer right battery cell.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
  43. Slide one corner of a plastic card under the outer edge of the battery cell. It may help to gently twist the card to open up a slight gap between the battery cell and the MacBook Pro's case. Slide the card farther underneath the battery cell to separate it from the adhesive securing it to the MacBook Pro's upper case.
    • Slide one corner of a plastic card under the outer edge of the battery cell.
    • It may help to gently twist the card to open up a slight gap between the battery cell and the MacBook Pro's case.
    • Slide the card farther underneath the battery cell to separate it from the adhesive securing it to the MacBook Pro's upper case.
  44. Lift the battery cell to separate it from the MacBook Pro's upper case, but don't try to remove it. Leave the plastic card underneath the battery cell to prevent it from re-adhering as you proceed to the next step.
    • Lift the battery cell to separate it from the MacBook Pro's upper case, but don't try to remove it.
    • Leave the plastic card underneath the battery cell to prevent it from re-adhering as you proceed to the next step.
  45. Apply a small amount of adhesive remover (approximately 1 ml) evenly along the elevated edge of the next battery cell. Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step. Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    • Apply a small amount of adhesive remover (approximately 1 ml) evenly along the elevated edge of the next battery cell.
  46. Slide one corner of your plastic card underneath the second battery cell. Push the card underneath the second battery cell, and slide it side to side to separate the adhesive underneath. Leave the plastic card underneath both battery cells (or flip them over) to prevent them from re-adhering as you proceed to the next step.
    • Slide one corner of your plastic card underneath the second battery cell.
    • Push the card underneath the second battery cell, and slide it side to side to separate the adhesive underneath.
    • Leave the plastic card underneath both battery cells (or flip them over) to prevent them from re-adhering as you proceed to the next step.
  47. It's time to switch sides. Remove your book or foam block and place it under the opposite side of your MacBook Pro. Repeat the procedure from the prior steps to separate the two battery cells on this side: Apply your adhesive remover to the elevated edge of the outer battery cell, and wait 2-3 minutes for it to penetrate.
    • It's time to switch sides. Remove your book or foam block and place it under the opposite side of your MacBook Pro.
    • Repeat the procedure from the prior steps to separate the two battery cells on this side:
    • Apply your adhesive remover to the elevated edge of the outer battery cell, and wait 2-3 minutes for it to penetrate.
    • Work one corner of a plastic card underneath the battery cell, and slide the card fully underneath the battery cell to separate it.
    • Do the same for the adjacent cell.
    • Leave your plastic card in place or flip the battery cells over to prevent them from re-adhering during the following steps.
  48. Remove your book or foam block and place it under the rear edge of your MacBook Pro, near the display hinges. Remove your book or foam block and place it under the rear edge of your MacBook Pro, near the display hinges.
    • Remove your book or foam block and place it under the rear edge of your MacBook Pro, near the display hinges.
  49. Grab the battery connector or the top edge of the plastic battery frame and lift it slightly, exposing the top edge of the two center battery cells. Grab the battery connector or the top edge of the plastic battery frame and lift it slightly, exposing the top edge of the two center battery cells.
    • Grab the battery connector or the top edge of the plastic battery frame and lift it slightly, exposing the top edge of the two center battery cells.
  50. While lifting the plastic battery frame out of the way, apply a small amount (about 1-2 ml) of adhesive remover underneath the top edge of the two remaining battery cells. Wait 2-3 minutes for the adhesive remover to penetrate before you continue. Wait 2-3 minutes for the adhesive remover to penetrate before you continue.
    • While lifting the plastic battery frame out of the way, apply a small amount (about 1-2 ml) of adhesive remover underneath the top edge of the two remaining battery cells.
    • Wait 2-3 minutes for the adhesive remover to penetrate before you continue.
  51. While lifting the plastic frame out of the way, push one corner of your plastic card underneath the outside edge of the first center battery cell. Do not pry along the edge nearest the battery connector, or you risk damaging the keyboard ribbon cable. Slide your card all the way under the battery cell, and leave it to prevent the battery cell from re-adhering.
    • While lifting the plastic frame out of the way, push one corner of your plastic card underneath the outside edge of the first center battery cell.
    • Do not pry along the edge nearest the battery connector, or you risk damaging the keyboard ribbon cable.
    • Slide your card all the way under the battery cell, and leave it to prevent the battery cell from re-adhering.
  52. Repeat the above procedure to separate the last remaining battery cell from the MacBook Pro's upper case. Repeat the above procedure to separate the last remaining battery cell from the MacBook Pro's upper case. Repeat the above procedure to separate the last remaining battery cell from the MacBook Pro's upper case.
    • Repeat the above procedure to separate the last remaining battery cell from the MacBook Pro's upper case.
  53. Lift the battery with the plastic frame and slide it back toward the MacBook Pro’s hinge until it clears the screw posts holding it to the upper case. Lift the battery with the plastic frame and slide it back toward the MacBook Pro’s hinge until it clears the screw posts holding it to the upper case.
    • Lift the battery with the plastic frame and slide it back toward the MacBook Pro’s hinge until it clears the screw posts holding it to the upper case.
  54. Lift and remove the battery. Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
    • Lift and remove the battery.
    • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each strip of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with a plastic tool. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your battery before using it: allow it to drain overnight, then charge it to 100% and drain it again until your MacBook Pro shuts down automatically. Charge it again and use it normally.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
Заключение
2 участников успешно повторили данное руководство.
Jeff Suovanen
Участник с: 06.08.2013
307 520 Репутация
Автор 255 руководств
Команда
iFixit Участник iFixit
Community
130 членов
Автор 12 512 руководств
Комментариев: 2
Thank you! Really good, easy to follow instructions with good informative pictures.
bigfatbassdrum - Ответить
Why does this guide insist on removing the logic board when it does not block removal of the battery? It’s not necessary to add those 30-40 steps to this process: this replacement can be done without taking out the logic board and all of the various risky wire pulls that it requires.
Ben Doherty - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 631
