Введение
Use this guide to help you replace a scratched, scuffed, bent or broken bottom panel on your MacBook Pro 15" Retina Display Early 2013.
Выберете то, что вам нужно
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Set the lower case aside.
12 участников успешно повторили данное руководство.
2 Comments
The difficulty is listed as moderate due to the specialized tools required to get into the device. Not everyone has a pentalobe driver laying around! =)
