Введение
The MacBook Pro 15" Retina Display Early 2013 packs the battery, keyboard, trackpad, and upper case into one assembly. If any of these components fail, the entire assembly must be replaced. Use this guide to replace your upper case assembly.
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Set the lower case aside.
Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
Slide the spudger underneath the length of the cover, releasing the adhesive.
Lift the cover and flip it back so that you can access the cables underneath.
Use your fingers to pull the AirPort/Camera cables up off the fan.
Carefully de-route the cables from the plastic cable guide.
Use the flat end of a spudger to pry the rubber hinge covers up off the left and right hinges.
Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge covers to the upper case.
Remove the two aluminum hinge brackets from the MacBook Pro.
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
Pull the AirPort card parallel out of its connector on the logic board to remove it.
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
Remove the following three screws securing the right fan to the logic board:
One 4.4 mm T5 Torx screw
One 3.9 mm T5 Wide Head Torx screw
One 5.0 mm T5 Torx screw with 2 mm collar
Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
Remove the following three screws securing the left fan to the logic board:
One 4.4 mm T5 Torx screw with 2 mm collar
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
Lift the left fan out of the device.
Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
Carefully lift the I/O board and remove it from the lower case.
Use the flat end of a spudger to pry the headphone jack connector up from its socket on the logic board.
Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Use the flat end of a spudger to gently back the keyboard ribbon cable out of its socket by pushing first at one side, then the other.
Use the flat end of a spudger to pry the trackpad ribbon cable connector up from its socket on the logic board.
Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
Pull the microphone ribbon cable out of its socket.
Use the tip of a spudger to pry the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near to the MagSafe 2 connector.
Remove the following six screws securing the logic board to to the upper case:
One 2.6 mm T5 Torx screw
Two 5.8 mm T5 Torx screws
One 3.8 mm T5 Torx screw
One 5.2 mm Raised Head T5 Torx screw
One 3.5 mm Silver T5 Torx screw
Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
Clockwise from top: keyboard, trackpad, battery, right speaker, keyboard backlight, display, microphone, headphone jack, left speaker.
Remove the single 2.6 mm T5 Torx screw securing the left rubber hinge cover in place.
Slide the hinge cover out of its bezel, then lift it up and out of the device.
Slide the right cover out of its bezel, then lift it out of the device.
Insert the edge of a plastic opening tool underneath the upper microphone.
Slide the blade of a plastic opening tool along the bottom of the upper microphone, releasing the adhesive.
In a similar manner, release the adhesive underneath the lower microphone.
Lift the cable out of the device.
Remove the two 4.0 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
Slide the MagSafe DC-In board towards the right free it from its recess within the upper case.
Lift and remove the MagSafe DC-In board out of the upper case assembly.
Remove the two 3.6 mm T5 Torx screws securing the headphone jack to the upper case assembly.
Slide the headphone jack away from the upper case.
Lift and remove the headphone jack out from its recess in the upper case.
Remove the following three screws securing the left speaker to the upper case:
One 5.6 mm T5 Torx screw
One 6.9 mm T5 Torx screw
Lift the left speaker out of the upper case and set it aside.
Remove the following three screws securing the right speaker to the upper case:
Remove the right speaker from the MacBook Pro.
Remove four out of the six 5.3 mm T8 Torx screws securing the display to the upper case.
While supporting both halves of the device with one hand, unscrew the upper 5.3 mm T8 Torx screw.
Grip both halves of the device. Firmly put one hand on the top center of the upper case (left) and one in the same place on the display assembly (right).
While holding the display assembly in place, slowly push forward on the upper case, releasing it from the display assembly.
22 участников успешно повторили данное руководство.
Один комментарий
Thanks for this guide, I now have working keyboard for this first time in years! Been bluetoothing a keyboard and finally had had enough. At first, i bought just the keyboard but after some research, realized I wan’t comfortable drilling out the 100+ rivets Apple put in there. Just transferred my trackpad (also an ifixit replacement from earlier), battery and all the internals with this step by step guide and it fired right back up. Extremely happy with this fix, almost like getting a new computer….. Almost. ;)
