Запчасти
Детали не указаны.
  1. Этот шаг не переведен. Помогите перевести
    Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer. Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  2. Этот шаг не переведен. Помогите перевести
    Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board. On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal. Carefully lift the I/O board and remove it from the lower case.
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
    • Carefully lift the I/O board and remove it from the lower case.
Финишная черта
2 участников успешно повторили данное руководство.
Brett Hartt
Участник с: 12.04.2010
121 812 Репутация
Автор 143 руководств
Команда
iFixit Участник iFixit
Community
137 членов
Автор 16 763 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 396
