Введение
Prereq for right fan and display assembly to disconnect and peel back airport and camera cables
Инструменты
Запчасти
Детали не указаны.
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
Use your fingers to pull the AirPort/Camera cables up off the fan.
Carefully de-route the cables from the plastic cable guide.
Еще один человек закончил это руководство.
