Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
Remove the left connector cover.
Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
Remove the right connector cover.
Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
Peel the I/O board cable up from the adhesive securing it to the fan.
Remove the cable.
3 участников успешно повторили данное руководство.
