Введение
The battery, keyboard, trackpad, and upper case are all stuck together. If you break one of these components, you will need to replace the entire assembly. Follow this guide to do so.
Выберете то, что вам нужно
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
Use your fingers to pull the AirPort/Camera cables up off the fan.
Carefully de-route the cables from the plastic cable guide.
Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
Remove the left connector cover.
Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
Remove the right connector cover.
Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
Peel the I/O board cable up from the adhesive securing it to the fan.
Remove the cable.
Use a T5 Torx driver to remove the following three screws securing the right fan to the logic board:
One 5.0 mm screw with a 2.0 mm long shoulder
One 4.0 mm screw with a wide head
One 4.4 mm screw
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
Lift the fan and push it gently towards the back edge of the MacBook to free the fan cable from its socket.
Remove the fan.
Remove the following three screws securing the left fan to the logic board:
One 3.6 mm T5 Torx screw with a wide head
One 5.0 mm T5 Torx screw with a 2.0 mm long shoulder
One 4.4 mm T5 Torx screw
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
Remove the fan.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Lift the end of the SSD up enough to pass over the speaker directly behind it.
Pull the SSD straight out of its socket on the logic board.
Use the point of a spudger to flip up the locking mechanism on the I/O board connector.
Flip the spudger around and use the flat end to slide the I/O cable out of the connector.
Slightly lift the interior edge of the I/O board and pull it toward the center of the MacBook, away from the side of the case.
Remove the I/O board.
Remove the two 2.2 mm Torx T5 screws securing the touchpad cable connector cover to the logic board.
Remove the cover.
Use the flat end of a spudger to disconnect the touchpad cable connector from its socket in the logic board.
Remove the following six screws securing the logic board assembly to the upper case.
One 3.8 mm T5 Torx screw
Two 5.7 mm T5 Torx screws
One 5.6 mm T5 Torx screw (this one is silver and has a taller head than the others)
One 2.6 mm T5 Torx screw
One 3.2 mm T5 Torx screw
The following steps will detail disconnecting these six connectors. Be sure to read each step, as these connectors come in different styles that disconnect differently.
Microphone cable
Left speaker cable
Keyboard data cable
Right speaker cable
Keyboard backlight cable
Display data cable
Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
Pull the microphone ribbon cable out of its socket, parallel to the logic board.
Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
Gently fold the cable up and out of the way of the logic board.
Use the tip of a spudger to flip up the retaining flap on the keyboard data cable ZIF socket.
Pull the keyboard data cable out of its ZIF socket. Be sure to pull parallel to the logic board, and not straight up.
Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board.
Use the point of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
Use the tip of a spudger to flip up the display data cable lock and rotate it toward the MagSafe 2 power port side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Gently bend the display data cable toward the display hinge, to expose the screws on the MagSafe 2 board.
Lift and pull the entire logic board assembly away from the wall of the upper case.
Remove the following screws securing the left speaker to the upper case:
2.7 mm T5 Torx screw
6.9 mm T5 Torx screw (with 4.5 mm shoulder)
Remove the left speaker by pulling it slightly away from the side of the upper case, and out from under the aluminum tab blocking it in.
Remove the following screws securing the right speaker to the upper case:
Remove the right speaker by pulling it slightly away from the side of the upper case, and out from under the aluminum tab blocking it in.
While gently pulling up on the microphone cable, push the flat end of a spudger underneath the cable, to cut the adhesive securing it to the upper case.
Remove the microphone cable.
Remove the two 3.2 mm T5 Torx screws securing the aluminum hinge covers to the upper case.
Remove four out of the six 5.3 mm T8 Torx screws securing the display to the upper case.
Leave the innermost screws (one from each hinge) in place.
Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower (closer to the table) display bracket.
While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
Grip both halves of the device, one in each hand.
Gently push forward on the bottom half of the device to detach it from the display assembly.
Carefully set each component aside, making sure to set down the bottom half keyboard-side down to avoid damaging internal components.
39 участников успешно повторили данное руководство.
2 Комментариев
Excellent instructions with great photos. After damaging my keyboard with coca-cola, I didnt know should I get a new keyboard or complete upper case. I went ahead and got complete case. This tutorial was very handy, better than any youtube video. Took me 5 hours to do it and now I am typing using the new keyboard. Thanks a lot.
Nicely done. Warnings much appreciated!
