MacBook Pro 15" Touch Bar 2018 Trackpad Replacement
Выберете то, что вам нужно
  1. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Disable Auto Boot: шаг 1, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Disable Auto Boot: шаг 1, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Disable Auto Boot: шаг 1, изображение 3 из 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - Ответить
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - Ответить
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - Ответить
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - Ответить
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - Ответить
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - Ответить
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - Ответить
    Not able to do that with damaged screen
    richardjgreen - Ответить
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - Ответить
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - Ответить
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - Ответить
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - Ответить
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - Ответить
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - Ответить
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - Ответить
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - Ответить
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - Ответить
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - Ответить
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - Ответить
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - Ответить
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - Ответить
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - Ответить
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - Ответить
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - Ответить
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - Ответить
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
  2. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Lower Case: шаг 2, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Lower Case: шаг 2, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 4.7 mm screws
    • Two 6.6 mm screws
    • Note how the screws come out at a slight angle—you must reinstall them the same way.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    I miss a printable template to leave the screws and removed parts on it for future identification when reassembly, linked maybe with the location in the Macbook, or with the number of the step.
    Juan Ignacio Fernández García - Ответить
  3. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 3, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 3, изображение 2 из 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle just enough to open a small gap under the lower case.
    Throw away this suction cup and get another. It just doesn't work! Luckily I had one that does work in my tool kit.
    Greek Taylor - Ответить
  4. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 4, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 4, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 4, изображение 3 из 3
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  5. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 5, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 5, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 5, изображение 3 из 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  6. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 6, изображение 1 из 1
    • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
    • Don't lift more than an inch or so, and don't try to remove the lower case yet.
  7. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 7, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 7, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 7, изображение 3 из 3
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
    With the amount of force needed to carefully pull the back panel out, this caused the back panel to scratch the battery. I don't see or hear any expansion, but this still has me concerned.
    gladgura - Ответить
    this step must require a lot of force. I tried to pull it with the plastic hookie thing from the ifixit set by hooking it in one of the screw holes — the tip of the hookie thing broke.
    Oleksii Toldaiev - Ответить
    The amount of force required for removing the bottom cover is absolutely ridiculous. Almost feels like i'm about to push my MacBook towards the wall the second it comes off.
    Be careful, I ended up breaking 2 grounding pins on the motherboard last time I tried opening my computer up.
    techtalkf - Ответить
    PLEASE DON'T PULL!!!
    Instead just gently push with plastic pick from the other side (where vents outputs are) towards the center... Cover will very easily open that way.
    I hope iFixit will correct this step.
    Kamil Roman - Ответить
    Came here to share exactly this.
    Robert -
    That's definitely how this step should be done. Thanks!
    VovS -
    If someone has a photo to share regarding this comment, it might be very useful. Thanks.
    Mark Cohen -
    I used a screwdriver at 45 degrees angle and pushed the cover from the hinges, it worked really smooth. I had it close to the corners.
    Martin Lundgren - Ответить
    Yeah, definitely don't pull; if you do, wear protective gloves. Mine was stuck so strongly that I just cut my palm quite deep.
    Kirill Chernov (PowerDoge) - Ответить
    You would think ifixit would investigate why the last step required them to pull with great force to remove the bottom case lid as the solution.
    It's counter-intuitive to use an excessive method to remove a part.
    There's always an easier way. It's frustrating because you can't see inside.
    Cary B - Ответить
    Using the iFixit opening Tool in the hinge opening required close to no force to open.
    Anders Markstrom - Ответить
    Ah... after attempting to 'pull' this rear cover off, to no avail, I tried to coax the cover off with a nylon pry tool. MUCH better! iFixIt will do well to amend it's recommendation to 'pull' this cover in any way. All I wanted to do was a little house cleaning and exorcize the dust bunnies that took up residence in my MBP's fans. Today is much quieter. Thank you all for pointing out the obvious.
    P.C. - Ответить
  8. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 8, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 8, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 8, изображение 3 из 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
    If I had it all to do over, again, I would blow out the dust with compressed air at this point. During the disassembly, I kept encountering little dust bunnies, and I was very worried that one would get caught in one of the connectors when I plugged everything back up (which wouldn’t get discovered until I put it all back together and tried out all of the components).
    Joe Emenaker - Ответить
  9. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Battery Connector: шаг 9, изображение 1 из 1
    • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
    • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
    • If the cover doesn't seat securely during reassembly, try rotating it 180 degrees. It must be oriented correctly in order for the adhesive pads underneath to contact the board screws.
    i need a ziff connector flap for step 10
    Gregg Gorin - Ответить
  10. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 10, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 10, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 10, изображение 3 из 3
    • Peel back any tape covering the battery board data cable connector.
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  11. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 11, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 11, изображение 2 из 2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
    • Slide parallel to the logic board, in the direction of the cable.
  12. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 12, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 12, изображение 2 из 2
    • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
  13. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 13, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 13, изображение 2 из 2
    • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
    • Take care not to install this cable backwards or upside-down. When installed correctly, the white liquid indicator sticker should face up, positioned directly over the battery power connector screw.
    Bonjour, super Tuto, petite question elle sert a quoi cette nappe , et quesqui se passe si elle est pas branché ?
    Jorgio -aigleBrun- - Ответить
  14. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 14, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 14, изображение 2 из 2
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 15, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 15, изображение 2 из 2
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
    Put a little bit of insulating tape over the terminal to be safe.
    Brian Tibbels - Ответить
    Agreed - once this is back in place, the system is energized, you run the risk of creating little sparks or worse if metal objects such as cover brackets accidentally touch areas of the logic board.
    bkbkbk - Ответить
  16. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Trackpad Assembly: шаг 16, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Trackpad Assembly: шаг 16, изображение 2 из 2
    • Use a T3 Torx driver to remove the two 1.9 mm screws securing the cover bracket for the keyboard and trackpad cable connectors.
    • Remove the bracket.
    I didn’t have T3 but T4 worked ;)
    For my 2018 model year MBP, all the "T3" screws referenced here and later in the guide were actually T4 for me.
    Mint137 - Ответить
  17. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 17, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 17, изображение 2 из 2
    • Use a spudger to disconnect the trackpad cable by prying its connector straight up from the logic board.
  18. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 18, изображение 1 из 1
    • Apply mild heat to the trackpad ribbon cable to soften the adhesive securing it to the battery.
    • You can use an iOpener, hair dryer, or heat gun, but be careful not to overheat the battery. The cable should be warm, but not too hot to touch.
  19. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 19, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 19, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 19, изображение 3 из 3
    • Carefully peel the trackpad cable up off the battery, and push it out of the way.
    • Don't crease or tear the cable. If you have trouble, don't force it—apply more heat and try again.
  20. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 20, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 20, изображение 2 из 2
    • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
    • Nine 5.8 mm screws
    • Four 4.9 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
    I dont have the “clicky” feedback from my trackpad anymore - please advise how to fix this
    Shadi Saif - Ответить
    The "clicky" feedback is achieved by electromagnet on the bottom, so for anyone like me who wanted to make sure it is working before connecting battery - it will not.
    Oleh Kasian -
    (MacBook Pro 2019 15” 2 years old) There are 4 screws (2 on the left and 2 on the right, each pair held down by a black metal piece) next to the uppermost 5.8mm screws. What is the size/kind of screw are these? I’d like to purchase these missing items? Please help. A suspicious technician tried to scam me out of money. I asked for my computer back before they could charge me. I decided to do the repairs myself. When I received my laptop back and followed Ifixit instructions I found 2 screws missing and they replaced the original with an unrecognizable rusty screw on the farthest left screw hole, and the black metal pieces were missing as well.
    Alathia Kaye - Ответить
  21. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 21, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 21, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 21, изображение 3 из 3
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • Carefully feed the trackpad's ribbon cable through its slot in the chassis.
    do not turn the touchpad over, as there are 4+5 very thin spacers/washers, and you might lose them. only the next step warns you about this. dont be me!
    George Kiss - Ответить
  22. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 22, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 22, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 22, изображение 3 из 3
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Remove the trackpad assembly.
    Und was wenn eine Trackpad Metallscheibe verloren geht?????Genau das ist mir gerade passiert. Muss ich mein Macbook jetzt wegschmeißen? HELP!
    Frank - Ответить
  23. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Trackpad: шаг 23, изображение 1 из 1
    • If your new trackpad didn't come with a ribbon cable, use the following three steps to remove and transfer the old ribbon cable to the new trackpad.
    • Use a spudger to pry up the retaining flap on the trackpad ribbon cable's ZIF connector.
  24. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 24, изображение 1 из 1
    • Apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive holding the end of the ribbon cable to the trackpad.
  25. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 25, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: шаг 25, изображение 2 из 2
    • Carefully slide the edge of a halberd spudger or opening pick underneath the ribbon cable, and work the tool back and forth to separate the cable from the trackpad.
    • Use minimal force, and apply more heat if needed.
    • Slide the ribbon cable out of its socket and remove it from the trackpad.
Заключение
9 участников успешно повторили данное руководство.
Jeff Suovanen
Участник с: 08/06/13
428 098 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
5 Комментариев
where can I buy the trackpad?
k4ss487 - Ответить
Did you manage to buy it somewhere?
Patrick Steiger -
Parts list with links to buy them is right at the top of the guide…
Jeff Suovanen -
Just replaced my trackpad, really easy to do! Thanks again guys!
Dimitri Prokas - Ответить
There are washers on these trackpad. If you lose one by accident, does it matter?
Wow - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 37
За последние 30 дней: 136
За всё время: 15,093
