Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Use the flat end of a spudger to pry the fan cable connector up off its socket on the logic board.
Remove the three identical T6 Torx screws securing the fan to the upper case.
20 участников успешно повторили данное руководство.
Один комментарий
One note of caution, beware of surprises. I had a problem with my Macbook Pro last summer and took it to Apple for repair and it turned out to be a settings issue and nothing mechanical but in the discovery process it was gutted and re-assembled. When it developed a fan problem last month I ordered a fan from Ifixit and went through the repair process. After removing the base plate it was then time to remove the fan using a Torx #6 screwdriver here is where the surprise was. Apple had substituted one of the three screws with a different type. Luckily I was able to find a screwdriver that worked.
So be be prepared for a possible surprise.
