Введение
Remove the lower case to access most of your MacBook Pro's internals.
Инструменты
Запчасти
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
26 участников успешно повторили данное руководство.
