Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide is an internal private guide used as a prereq.
Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
Disconnect the camera cable by pulling the male end straight away from its socket.
Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
Lift the Bluetooth board/cable retainer assembly out of the upper case.
Use a spudger to pry the optical drive connector straight up off the logic board.
Remove three 3.5 mm Phillips screws securing the optical drive to the upper case.
Еще один человек закончил это руководство.
