Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide is prereq only.
Выберете то, что вам нужно
Pull the camera cable connector straight out of its socket on the logic board.
Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
Use the tip of a spudger to pry the four antenna connectors up from their sockets on the AirPort/Bluetooth board.
De-route all four antenna cables from their channels in the AirPort/Bluetooth housing.
De-route the camera cable from its channel in the AirPort/Bluetooth housing.
Remove the following two screws securing the AirPort/Bluetooth assembly to the upper case:
One 8.6 mm Phillips screw
One 3.9 mm Phillips screw
Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
