Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
Use the flat end of a spudger to disconnect the left fan connector from the logic board.
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board.
Lift the right fan out of its opening in the logic board.
Pull the camera cable out of its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board.
Lift the cover off the logic board and set it aside.
Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
Pull the keyboard backlight ribbon cable out of its socket.
Remove the following nine screws:
Seven 3.4 mm ( 3.1 mm) T6 Torx screws on the logic board
Two 8 mm T6 Torx screws on the DC-In board
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
If necessary, use the flat end of a spudger to separate the microphone from the upper case.
Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
Remove the two 7.5 mm ( 7.2 mm )Tri-point screws securing the battery to the upper case.
Carefully peel the battery warning label off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
Remove the last 7.5 mm ( 7.2 mm ) Tri-point screw securing the battery to the upper case.
Use the attached plastic pull tab to remove the battery from the upper case.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Remove the hard drive bracket from the upper case.
Using its attached pull tab, lift the hard drive out of the upper case.
Pull the hard drive connector out of its socket on the hard drive.
Remove the hard drive and set it aside.
Remove the following four screws securing the hard drive/IR sensor cable to the upper case:
Two 2.5 mm ( 2.9 mm ) Phillips screws
Two 10 mm ( 9.6 mm ) Phillips screws
Carefully peel the IR sensor cable off the adhesive securing it to the upper case.
Pull the hard drive bracket/IR sensor housing away from the side of the upper case.
Remove the hard drive/IR sensor cable from the upper case.
Use the tip of a spudger to pry the four antenna connectors up from their sockets on the AirPort/Bluetooth board.
De-route all four antenna cables from their channels in the AirPort/Bluetooth housing.
De-route the camera cable from its channel in the AirPort/Bluetooth housing.
Remove the following two screws:
One 8.6 mm ( 8.4 mm ) Phillips screw
One 3.9 mm Phillips screw
Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
Remove the three 3.5 mm ( 3.3 mm ) T6 Torx screws securing the optical drive to the upper case.
Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
Remove the following six screws securing the subwoofer and right speaker to the upper case:
Two 3.2 mm ( 3.0 mm ) Phillips screws.
Two 12.3 mm Phillips screws.
One 2.5 mm Phillips screw.
One 8.3 mm ( 8.1 mm ) Phillips screw.
Lift the subwoofer and right speaker assembly out of the upper case.
Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the top left portion of the upper case.
Remove the antenna/camera cable retainer from the upper case.
Remove the 8.6 mm ( 7.0 mm ) Phillips screw securing the display data cable retainer to the top right portion of the upper case.
Remove the display data cable retainer from the upper case.
Remove two of the three 6 mm T6 Torx screws securing the right side of the display to the upper case.
Remove two of the three 6 mm T6 Torx screws securing the left side of the display to the upper case.
Open your MacBook Pro so the display is perpendicular to the upper case.
Place your opened MacBook Pro on a table as pictured.
While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the upper display bracket.
Remove the last remaining T6 Torx screw securing the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
If your replacement includes the battery level indicator, stop here.
Remove three 2.0 mm Phillips #00 screws securing the battery level indicator to the upper case.
Use the tip of a spudger to gently pry up the edge of the metal shield covering the battery level indicator cable.
56 участников успешно повторили данное руководство.
6 Комментариев
I ordered a new topcase for my early 2011 MBP from We Love Macs in CA after I accidentally spilled beer on mine (sob) and after cleaning/drying everything worled but the power switch. This guide walked me through it beautifully and I now have a working MBP again! Thanks so much iFixit.
This task is definitely for a more technically inclined person. There are a lot of fragile connectors that can be damaged, and even though I am very technically inclined I had sweat on my brow the whole way through. Follow the directions carefully and keep all the small parts separate from each step so you won't get confused when you put it all back. Also, the tools from ifixit, or similar ones are a must.
Thanks iFixit!
I replaced my trackpad and battery. Now it freezes when I click the trackpad, moving the cursor works fine and it works fine with an external mouse too. Any idea what might cause the issue?
Thanks a lot for this tutorial, I was able to replace my faulty keyboard (even though the tutorial doesn't go this far, I managed to figure it out ^^).
Next step is to bake my logic board to fix GPU well-known issue…
Hi, is there any parts removed in this tutorial that do not require removal to replace the keyboard? I need to do this myself, and dont want to remove unnecessary parts
