Введение
This guide will show you how to remove the Access Door from your laptop.
Инструменты
Инструменты не указаны.
Запчасти
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
The access door should now be raised enough to lift it up and out of the Unibody.
40 участников успешно повторили данное руководство.
