MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement
Выберете то, что вам нужно
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement, Access Door: шаг 1, изображение 1 из 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement, Access Door: шаг 1, изображение 2 из 2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 2, изображение 1 из 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement, Battery: шаг 3, изображение 1 из 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement, Lower Case: шаг 4, изображение 1 из 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 5.4 mm Phillips screw.
    • Three 14 mm Phillips screws.
    • Four 3.5 mm Phillips screws.
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 5, изображение 1 из 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement, Mid Wall: шаг 6, изображение 1 из 1
    • Remove the following 5 screws securing the mid wall to the upper case:
    • Three 10.5 mm Phillips screws.
    • Two 3.7 mm Phillips screws.
  7. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 7, изображение 1 из 1
    • Lift the mid wall out of the upper case.
  8. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement, Logic Board: шаг 8, изображение 1 из 1
    • Remove the following six screws securing both the right fan and the left fan to the logic board:
    • Two 3.2 mm Phillips screws.
  9. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 9, изображение 1 из 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 9, изображение 2 из 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 9, изображение 3 из 3
    • Use the tip of a spudger to lift the right fan connector straight up from its socket on the logic board.
    • Be sure to only pry up on the connector itself not on the socket or you may damage the machine.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • Remove the right fan from the case.
  10. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 10, изображение 1 из 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 10, изображение 2 из 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 10, изображение 3 из 3
    • Use the tip of a spudger to lift the left fan connector straight up from its socket on the logic board.
    • Remove the left fan from the case.
  11. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 11, изображение 1 из 1
    • Remove any adhesive from the camera cable connector.
    • Disconnect the camera cable by pulling the male end out of its socket, parallel to the logic board, do not lift it upwards.
  12. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 12, изображение 1 из 1
    • Use a spudger to carefully pry the optical drive connector straight up off its socket on the logic board.
  13. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 13, изображение 1 из 1
    • If necessary, peel off the foam bumper covering the subwoofer connector.
    • Using the flat end of a spudger, pry the subwoofer connector straight up off its socket on the logic board.
    • Be very careful. This connection is delicate, the socket can be easily broken off the logic board.
  14. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 14, изображение 1 из 1
    • Use the flat end of a spudger to pry the silver-colored hard drive cable connector straight up out of its socket on the logic board.
  15. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 15, изображение 1 из 1
    • Use a spudger to pry the trackpad connector straight up out of its socket on the logic board.
  16. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 16, изображение 1 из 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 16, изображение 2 из 2
    • Using the tip of a spudger, flip up the IR/sleep LED ribbon cable retaining flap.
    • Pull the IR/sleep LED ribbon cable straight out of its socket.
  17. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 17, изображение 1 из 1
    • Use a spudger to pry the battery indicator light connector straight up out of its socket on the logic board.
    • Pry up under the cable wires to avoid pulling the socket itself off of the logic board.
  18. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 18, изображение 1 из 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 18, изображение 2 из 2
    • Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
    • Pull the keyboard ribbon cable straight out of its socket.
    • During reassembly, make sure to fully insert the keyboard ribbon cable back into the ZIF socket.
  19. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 19, изображение 1 из 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 19, изображение 2 из 2
    • Using the tip of a spudger, flip up the express card cage ribbon cable retaining flap.
    • Pull the express card cage ribbon cable straight out of its socket.
  20. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 20, изображение 1 из 1
    • Using the flat end of a spudger, pry the microphone cable connector straight up out of its socket on the logic board.
  21. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 21, изображение 1 из 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 21, изображение 2 из 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
    • When disconnecting the display data cable, do not pull on the black tab secured to the cable lock. We recommend wiggling the cable while applying tension to slowly "walk" the connector out of its socket.
    • Make sure the display data cable is placed correctly in its socket during reassembly. Failure to do so will result in a partially visible display or no display image at all.
  22. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 22, изображение 1 из 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 22, изображение 2 из 2
    • Locate the keyboard backlight ribbon cable (near the left fan space).
    • Using the tip of a spudger, flip up the keyboard backlight ribbon cable retaining flap.
    • Pull the keyboard backlight ribbon cable straight out of its socket.
  23. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 23, изображение 1 из 1
    • Remove seven 3.2 mm Phillips screws securing the logic board to the upper case.
    • Do not remove the logic board yet! There are connectors attached to the underside of the logic board that must first be disconnected.
  24. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 24, изображение 1 из 1
    • Remove two 7 mm Phillips screws securing the DC-in board to the upper case.
    • Note: This step is not completely necessary, but it will make it easier to disconnect the cable that is connected to the DC-in board.
  25. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 25, изображение 1 из 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 25, изображение 2 из 2
    • Remove two 3.5 mm Phillips screws securing the bottom case clip to the upper case.
    • Lift the bottom case clip out of the upper case.
    • Some MacBook Pro Unibodies do not have a bottom case clip and do not require this step.
  26. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 26, изображение 1 из 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 26, изображение 2 из 2
    • Carefully lift the logic board assembly from the left side and work it out of the upper case, minding the port side that may get caught during removal.
    • Do not entirely remove the logic board yet!
    • Ensure that the logic board is free from all connections to the upper case (except the battery connector) before proceeding.
    • During reassembly, ensure all connectors and cables are not placed underneath the logic board. Some of the ribbon cables are very thin and fragile.
  27. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 27, изображение 1 из 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 27, изображение 2 из 2
    • Lift the logic board enough to grab the battery connector and pull it straight away from its socket on the logic board.
    • Lift the logic board assembly out of the upper case.
  28. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement, Heat Sink: шаг 28, изображение 1 из 1
    • Remove eight 8.4 mm Phillips screws securing the heat sink to the logic board.
    • A spring is held under each of these screws.
  29. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 29, изображение 1 из 1
    • Use the tip of a spudger to pry the thermal sensor connector up off the logic board.
    • This connector is especially delicate, so be sure to use extreme caution when removing it.
  30. MacBook Pro 15" Unibody Late 2008 and Early 2009 Heat Sink Replacement: шаг 30, изображение 1 из 1
    • Gently lift the heat sink off the logic board.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Заключение
28 участников успешно повторили данное руководство.
4 Комментариев
Wonder why there are springs on the heat sink screws? Do not over tighten them, the springs are there to help you apply the correct amount of pressure on to the CPU and GPU. If you tighten them all the way, it may not be the correct pressure! Leave maybe 1 mm of space, just before the screw stops turning. iFixit forgot to mention this important part, and also in the heat paste guide!!
m3kw - Ответить
My Macbook was over heating. i did these steps to put thermal paste but now my Macbook pro is not even opening.. please help..!!
Deepanshu Chaurasia - Ответить
My old Macbook was getting pretty hot (90-110 C on the main processor temperature sensor) doing normal tasks so I decided it was probably the thermal paste going bad. Successfully completed this using this guide, typing this on that computer now, thanks! It took me about 3 hours all in, including setup and cleanup afterwards. I did not replace the heat pipe assembly itself, just redid the thermal paste. I am actually curious what the symptoms are that would lead to completely replacing the heat pipe assembly itself. Running much cooler now (59 C).
Trevor Kemp - Ответить
I went through this last night to the T, made sure to be careful and put all cables back properly. Now when I start the laptop I get the startup noise, the screen will flicker really quick but then go back to black and stays black indefinitely. The keyboard lights come on and the laptop is running fine just no display. I’ve tried all the resetting pram and all of that to no avail. I have reseated the lcd cable multiple times and still have a black screen. At a loss.
Patrick Scroggins - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 34
За всё время: 37,247
