Введение
Use this guide to replace a burned-out right fan.
Выберете то, что вам нужно
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Use a spudger to pry the fan connector straight up off the logic board.
Remove three T6 Torx screws securing the right fan to the logic board and upper case.
27 человек успешно провели ремонт по этому руководству.
