Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide is an internal prereq that should remain unpublished.
Выберете то, что вам нужно
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Lift the the retaining bracket out of the upper case.
Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
Remove the hard drive cable by pulling the hard drive straight away from the connector. Keep the connector steady. If pulled by the connector, it can be pulled too far and accidentally tear the hard drive cable.
