MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement
Выберете то, что вам нужно
  1. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Seven 3 mm Phillips screws.
    May be helpful to have more distinct colors to identify the different screws.
    Victor Caamano - Ответить
  2. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 2, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 2, изображение 2 из 2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement, Battery: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
    $5.49
    Купить
    • Remove the two 5-Point Pentalobe screws along the top edge of the battery.
    • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
    Question: why do you remove the battery? According to Apple's official manual, this is not required (not for the mid-2009 and not for the mid-2010 15-inch MacBook Pro) - see pages 37 ff:
    http://manuals.info.apple.com/en_US/MacB...
    alexkli - Ответить
    I'm interested by your experience.
    Did you have removed the optical drive without removing the battery ?
    I'm just in this step now and if it is possible I would proceed like you because removing the battery void the warranty (and there is a sticker).
    Thanks in advance.
    youyou - Ответить
    Looks like my note to step 3 appears on all repair guides that have the same step. I meant that in the context of the hard drive replacement only.
    I haven't yet done anything, waiting for my MacBook Pro 15 inch mid-2010 to arrive.
    alexkli - Ответить
    I missed the notes and went ahead and purchased the 5 point driver for the battery before I realized it was not necessary.
    I've edited the repair guide to remove the section on the battery, but I don't have the points to approve the changes.
    Chris Davis -
    Please note - the step about removing the battery is part of a pre-requisite guide, that is used for many of the guides, most that do require removal of the battery. Also, working inside a disassembled laptop with the battery still connected risks damaging/shorting out very expensive parts.
    Eric Essen - Ответить
    Absolutely. To be clear -- ALL of the above discussion is ONLY in reference to replacing the hard drive.
    Chris Davis -
    I replaced a hard drive in a MacBook Pro of an earlier model than this without removing the battery. The hard drive wasn't right. It only worked at about half speed, and I had to replace it once more. The second time I removed the battery and all went well. The recommendation by the iFixit staff to remove the battery before working on electronic equipment is a good one.
    doug - Ответить
    What is the size of those screws... I have rounded off the socket on mine and would like to replace them.
    Ghatothkach Yadav - Ответить
    I measured the screw size, using a micrometer, its about 1.523mm in diameter and 3.186mm in length. Not sure what screw size that is. They are not easily available I guess, unless someone is selling used ones on ebay
  4. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 4, изображение 1 из 1
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove third five-point Pentalobe screw hidden underneath.
  5. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 5, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 5, изображение 2 из 2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
    Removing the battery is not necessary for the hard drive removal/replacement procedures.
    Erik - Ответить
    My T6 (appears to be same screw driver you have - $6 on amazon for 20piece set) did NOT fit int he battery screws...not sure if I had the wrong screws or what, but I went ahead w/o battery steps and it was pretty easy.
    Anthony Ettinger - Ответить
    I also noticed that the new SDD (from crucial) didn't have the 4 screws, so I had to move those off the old HD and onto the new one.
    Anthony Ettinger -
    Just had the same issue: T6 does not fit the battery screws ;-( ... but with a little bit more preassure it was possible to remove the screws.
    dirkvloenwagner -
  6. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 6, изображение 1 из 1
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it after installation.
  7. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement, Optical Drive: шаг 7, изображение 1 из 1
    • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
    I found it quite easy to carefully remove the drive from under the camera cable without disconnecting it, and guide the new drive back in under. It saved time and the danger of damaging those fragile connectors.
    Glenn Richards - Ответить
  8. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 8, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 8, изображение 2 из 2
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Pull the connector parallel to the face of the logic board, not straight up.
    I would recommend leaving the camera cable plugged into the motherboard, and simply sliding the optical drive out from underneath it carefully. If you mistakenly life this connector straight up (as I did) you can damage either the cable connector or the motherboard socket. I damaged the connector on the cable and now the wifi antenna doesn't work. Replacing this damaged cable is about 10X more of a pain (in time and money) than the effort to slide the optical drive out from beneath this cable instead of disconnecting it.
    Frank Stickney - Ответить
    I agree, the same issue happened to me (My MBP no longer recognizes its wi-fi adapter). The black connector is very fragile, and very hard to slide back in after you take it out. Try not to disconnect it if you can.
    Dave Yu - Ответить
    Totally agree here, my wifi card is no longer recognized by the computer. Not sure what to do now.
    raj grainger - Ответить
    100% true! Thanx for confirming
    cj67 - Ответить
  9. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 9, изображение 1 из 1
    • Peel the camera cable off the adhesive securing it to the optical drive.
    When reassembling, which adhesive should be used to reattach the camera cable?
    Daniele Tamponi - Ответить
  10. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 10, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 10, изображение 2 из 2
    • This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
    How can I determine if I have an antiglare display?
    Thanks!
    Dan
    Dan Neunaber - Ответить
    If you have the part in step 10, you do. If you don’t, you don’t (looks like pic in step 9).
    maccentric -
    As already pointed out in a comment to step 8, it is possible to slide carefully out the drive from underneath the bluetooth board without touching it, and to insert the replacement drive in the same way, avoiding to perform this step and the next one.
    spiderbatbug spiderbatbug - Ответить
  11. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 11, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 11, изображение 2 из 2
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
  12. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 12, изображение 1 из 1
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  13. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 13, изображение 1 из 1
    • Remove the single 3.5 mm Phillips screw securing the inner side of the optical drive to the upper case.
    Totally stripped this screw, no idea what to do know.
    What - Ответить
  14. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 14, изображение 1 из 1
    • Remove the two 3.5 mm Phillips screws securing the outer side of the optical drive to the upper case.
    When installing the HD bay, the screws here will not go back. Not sure if the bracket/holes are somehow different. After completing the install, everything seems secure. Does anyone think not having these screws is critical beyond securing the drive?
    toddfletcher - Ответить
  15. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 15, изображение 1 из 1
    • Lift the optical drive from its left edge and pull it out of the upper case.
  16. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement, Optical Drive: шаг 16, изображение 1 из 1
    • Remove the optical drive cable by pulling it straight away from the optical drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  17. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: шаг 17, изображение 1 из 1
    • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
Заключение
49 участников успешно повторили данное руководство.
4 Комментариев
My replacement drive had screwholes in slightly different places and a different connector ribbon, but I was able to successfully swap the drive top plate, inner side screw bracket and connector ribbon with the ones from the existing drive.
Steve Seear - Ответить
Replaced the drive. DVD inserts. Drive works. But the DVD won't eject. Seems like the slot in the case and the drive don't align. Any Ideas?
Gabriel Lieb - Ответить
Do you think, It’s a good solution to remove the drive without replacing it?
Oliver - Ответить
I just replaced drive…tried to insert disk and no go. Do I need to reset something software wise??
Doe - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 35
За всё время: 79,275
