Введение
Is the right side of your MacBook Pro mute? Use this guide to replace the subwoofer & right speaker assembly.
Запчасти
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
Use the tip of your finger to carefully peel back the corner of the warning label to reveal a hidden Tri-point screw.
Remove the last 7.4 mm Tri-point screw securing the battery to the upper case.
Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
Tilt the battery away from the logic board enough to access the battery cable connector.
Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
Disconnect the camera cable by pulling its connector away from the socket (toward the optical drive) on the logic board.
Use the flat end of a spudger to pry the optical drive connector up off the logic board.
Remove the two Phillips screws securing the AirPort/Bluetooth board housing.
Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
Remove the following three Phillips screws securing the optical drive to the upper case:
One 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
Two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
Peel the hard drive cable up from the channel within the subwoofer and right speaker.
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Remove the following six screws securing the subwoofer and right speaker to the upper case:
Two 3.2 mm Phillips screws.
Two 12.3 mm Phillips screws.
One 2.5 mm Phillips screw.
One 8.3 mm Phillips screw.
23 участников успешно повторили данное руководство.
