Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the following six screws:
Two 14.5 mm T6 Torx screws on either side of the RAM slot.
Four 3.4 mm Phillips screws along the hinge.
Remove the four 3.4 mm Phillips screws on the port side of the computer.
Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Disconnect the trackpad and keyboard ribbon cable from the logic board.
Remove the upper case.
Disconnect the two antenna cables attached to the AirPort Extreme card.
Remove the single black T6 Torx screw from the top right corner of the AirPort Extreme card.
Lift the AirPort Extreme card up and slide it out of its connector.
3 участников успешно повторили данное руководство.
