MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement
Выберете то, что вам нужно
  1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, Battery: шаг 1, изображение 1 из 1
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
  2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, RAM Shield: шаг 2, изображение 1 из 1
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 3, изображение 1 из 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, Upper Case: шаг 4, изображение 1 из 1
    • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 5, изображение 1 из 1
    • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
  6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 6, изображение 1 из 1
    • Remove the four 3.4 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 7, изображение 1 из 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 8, изображение 1 из 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 9, изображение 1 из 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  10. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 10, изображение 1 из 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board.
    • Remove the upper case.
  11. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, Display: шаг 11, изображение 1 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, Display: шаг 11, изображение 2 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, Display: шаг 11, изображение 3 из 3
    • Disconnect the two antenna cables from the AirPort Extreme card, the iSight and inverter cables from the left side of the logic board, and the display data cable from the right side of the logic board. Be careful to slide the connectors as they may become damaged otherwise.
    • For A1229 and A1212 models, disconnect the three antenna cables from the AirPort Extreme card and the three connectors highlighted on the logic board.
    • For the A1229, the order of the cables from left to right is: Black (left; towards the edge of the case) — Grey (middle) — Blue (right; towards the middle of the case.
    • For the A1261 model, disconnect the two antenna cables from the AirPort Extreme card and the three connectors highlighted on the logic board.
    • Carefully peel the iSight and inverter cables off the top of the left fan and de-route the AirPort antenna cables from the channel in the left speaker.
  12. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 12, изображение 1 из 1
    • Remove the ten silver T6 Torx screws securing the display (five on each side-take note that the inside screws on both sides are longer with a thinner head).
    • Don't forget to replace the hinge end caps when reinstalling the display assembly. The end caps are side specific, so be sure that the posts are facing towards the lower case.
  13. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 13, изображение 1 из 1
    • Grasp the display assembly on both sides and lift it up and out of the computer.
  14. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, Rear Display Bezel: шаг 14, изображение 1 из 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, Rear Display Bezel: шаг 14, изображение 2 из 2
    • The hinge end caps on this model can be easily removed at this point, as they are not fastened to the hinge and may fall off during service.
    • Remove the Phillips screws from the lower left and right corners of the display (two screws total).
  15. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 15, изображение 1 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 15, изображение 2 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 15, изображение 3 из 3
    • Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
    • Do not insert your spudger between the plastic strip and the rear bezel.
    • With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
    • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
  16. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 16, изображение 1 из 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 16, изображение 2 из 2
    • Insert your spudger between the front and rear display bezels at the lower right corner of the display.
    • Pry the rear bezel away from the front bezel to slightly separate the bottom edge of the rear display bezel.
  17. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 17, изображение 1 из 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 17, изображение 2 из 2
    • Insert the flat end of a spudger into the gap between the rear display bezel and the clutch cover.
    • Twist the spudger to separate the lower edge of the rear display bezel from the clutch cover.
    • Work along the lower edge of the rear bezel until it is evenly separated from the clutch cover.
  18. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 18, изображение 1 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 18, изображение 2 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 18, изображение 3 из 3
    • Now that the right and bottom edges of the rear bezel are slightly separated from the front bezel, use a spudger to pop the rear bezel off the tabs near the lower right corner of the display.
  19. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 19, изображение 1 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 19, изображение 2 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 19, изображение 3 из 3
    • Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
    • Rotate your spudger toward the rear bezel to separate it from the front bezel.
    • If necessary, continue separating the left edge of the rear bezel off the tabs on the front display bezel.
  20. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 20, изображение 1 из 1
    • Slightly lift the lower edge of the display and pull it away from the rear display bezel.
    • The rear display bezel remains.
  21. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, LCD: шаг 21, изображение 1 из 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement, LCD: шаг 21, изображение 2 из 2
    • Remove the strip of tape covering the backlight leads.
    • Carefully lift the inverter out of the clutch cover enough to reach the backlight connector.
  22. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 22, изображение 1 из 1
    • Disconnect the backlight cable from the inverter board.
  23. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 23, изображение 1 из 1
    • Remove the several strips of tape securing the ribbon cables to the LCD.
  24. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 24, изображение 1 из 1
    • Use the flat end of a spudger to carefully peel the three antenna strips off the lower edge of the LCD.
    • Work carefully, as these strips may tear in the process.
  25. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 25, изображение 1 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 25, изображение 2 из 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 25, изображение 3 из 3
    • Use the tip of a spudger or your fingernail to flip up the ZIF retaining flap on the camera cable socket at the edge of the camera board near the top center of the front display bezel.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the camera cable out of its socket.
    • Peel the camera cable off the foam tape along the top edge of the display.
  26. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 26, изображение 1 из 1
    • Pull the display data cable toward the bottom edge of the display to disconnect it from the LCD.
  27. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 27, изображение 1 из 1
    • Remove the four 3.2 mm Phillips screws along the right edge of the display.
  28. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 28, изображение 1 из 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 28, изображение 2 из 2
    • Remove the two 3.2 mm Phillips screws on the top edge of the display.
  29. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 29, изображение 1 из 1
    • Remove the four 3.2 mm Phillips screws along the left edge of the display.
  30. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 30, изображение 1 из 1
    • The next few steps will require you to separate the LCD from the adhesive applied to the upper and lower edges of the front bezel.
    • The adhesive is applied such that it sticks to a thin steel strip around the perimeter of the LCD. When prying your LCD away from the front panel, be sure you are separating the front panel from the steel strip on the LCD.
    • Use the flat end of a spudger to gently lift one of the top corners of the LCD out of the front bezel.
  31. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 31, изображение 1 из 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 31, изображение 2 из 2
    • Work your way along the top edge of the LCD, slowly prying the attached steel strip away from the front bezel.
    • Continue prying the LCD off the front bezel along the left side of the display.
  32. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 32, изображение 1 из 1
    • Now that the top and left edges are free, slightly lift the LCD out of the front bezel for enough room to pry the steel strip along the lower edge of the LCD away from the front bezel.
    • Pry along the lower edge of the LCD until it is freed from the adhesive on the front bezel.
  33. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 33, изображение 1 из 1
    • Lift the LCD out of the front bezel, minding any cables that may get caught.
    • Replacement Note: there are clear plastic spacers attached via adhesive to the sides and bottom of the lcd panel. Be sure to transfer these spacers to the replacement panel for optimum fit.
  34. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 LCD Replacement: шаг 34, изображение 1 из 1
    • Before reassembling the display, be sure to reinstall the magnet shown into its recess cut into the right edge of the front display bezel.
    • Failure to reinstall this magnet will prevent your MacBook Pro from entering sleep mode when the display is closed.
Заключение
50 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Be sure to reset the PRAM after installation. Otherwise the image may be garbled.
Lee - Ответить
If you don't mind downgrading the resolution from 1680x1050 to 1440x900, you can use another LCD Panel used for 17" Toshiba laptops: LTN170X2-L02. It's almost the same size and spec-wise, except for the lower res...and can be found much cheaper ($50 to $80). The only caveat is that the backlight cable comes out in a slightly different place, and you have to dremel away some of the lid so it doesn't pinch the backlight cable. I was interested to see if the Mac would recognize it, as 1440x900 was not one of the official resolutions mentioned in the original MacBook specs, but it worked!
Frank Zimmerman - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 17
За последние 7 дней: 111
За последние 30 дней: 264
За всё время: 53,483
