MacBook Pro 17" Unibody Hard Drive Bracket Replacement
Выберете то, что вам нужно
  1. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: шаг 2, изображение 1 из 2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: шаг 2, изображение 2 из 2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: шаг 3, изображение 1 из 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: шаг 3, изображение 2 из 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: шаг 3, изображение 3 из 3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive: шаг 4, изображение 1 из 1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: шаг 5, изображение 1 из 1
    • Remove the hard drive bracket from the upper case.
  6. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: шаг 6, изображение 1 из 1
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
  7. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: шаг 7, изображение 1 из 2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: шаг 7, изображение 2 из 2
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
  8. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive Bracket: шаг 8, изображение 1 из 1
    • Remove the two 5 mm Phillips #00 screws securing the hard drive bracket to the upper case.
  9. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: шаг 9, изображение 1 из 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: шаг 9, изображение 2 из 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: шаг 9, изображение 3 из 3
    • Tilt the outer hard drive bracket up toward the logic board and remove it from the rear case.
Заключение
10 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 10/18/12
457 183 Репутация
Автор 537 руководств
Команда
iFixit Участник iFixit
Community
138 членов
Автор 16 926 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 23
За всё время: 4,389
