Выберете то, что вам нужно
Turn the computer over and remove all of the screws that holds together the bottom of the case.
The bottom left three screws are longer. Set those aside for reassembly
Delicately lift the case off. The hard drive is visible. There is a bracket with two black screws holding it in place. Remove the bracket and you have access to the hard drive.
Remove the interface from the SATA drive and leave the ribbon connected to the mobo.
19 участников успешно повторили данное руководство.
