MacBook Pro Hard Drive Removal
Выберете то, что вам нужно
  1. MacBook Pro Hard Drive Removal, Power off MacBook Pro: шаг 1, изображение 1 из 2 MacBook Pro Hard Drive Removal, Power off MacBook Pro: шаг 1, изображение 2 из 2
    • Turn the Macbook Pro off and unplug all power sources. There is a possibility of danger if the Macbook Pro has power when the hard drive is removed.
    • Flip the Macbook Pro over so the Apple logo is on the table and the black laptop hinge is furthest from you.
  2. MacBook Pro Hard Drive Removal, Remove Screws: шаг 2, изображение 1 из 2 MacBook Pro Hard Drive Removal, Remove Screws: шаг 2, изображение 2 из 2
    • Unscrew ten screws using a Phillips #000 screwdriver. Push screwdriver into screw and then turn, keeping firm pressure on the screwdriver, to avoid stripping the screw.
    • After unscrewing a screw, place it next to the hole it was taken from. When it is time to replace the screws this will avoid any confusion, as there are several longer screws.
    The two closest to the rear hinge are the short screws
    lucas - Ответить
  3. MacBook Pro Hard Drive Removal, Remove Back Cover: шаг 3, изображение 1 из 1
    • Lift back cover off of your MacBook Pro and set aside. It might make a loud sound and that is okay.
  4. MacBook Pro Hard Drive Removal, Find Hard Drive: шаг 4, изображение 1 из 1
    • Locate the hard drive. With the hinge facing away from you, the hard drive can be found in the bottom left corner closest to you. It is rectangular and silver.
  5. MacBook Pro Hard Drive Removal, Remove Black Bar: шаг 5, изображение 1 из 2 MacBook Pro Hard Drive Removal, Remove Black Bar: шаг 5, изображение 2 из 2
    • Locate the black bar holding the hard drive in place. This bar is on the top of the hard drive.
    • Loosen the two black screws on the black bar using the screwdriver. Make sure to not unscrew the silver screws.
    • Pull the black bar off of the hard drive. Set it aside.
  6. MacBook Pro Hard Drive Removal, Lift Hard Drive out of MacBook Pro: шаг 6, изображение 1 из 2 MacBook Pro Hard Drive Removal, Lift Hard Drive out of MacBook Pro: шаг 6, изображение 2 из 2
    • Pull plastic tab to lift the hard drive out of place.
  7. MacBook Pro Hard Drive Removal, Detach Hard Drive from Black Bar: шаг 7, изображение 1 из 2 MacBook Pro Hard Drive Removal, Detach Hard Drive from Black Bar: шаг 7, изображение 2 из 2
    • Carefully pull the black bar attached to side of hard drive off. This black bar will still be attached to the computer.
Заключение
To install a new hard drive into this computer, follow these instructions in reverse order. Begin by unscrewing the mounting screws from the old hard drive and screwing them into the new hard drive.
If you plan to use the current hard drive as an external hard drive, leave the mounting screws in place. Purchase a hard drive enclosure to keep the hard drive in.
43 участников успешно повторили данное руководство.
McKaila Ruud
Участник с: 03/29/17
746 Репутация
1 руководство автора
Команда
Accidental Lekage Участник Accidental Lekage
Repair Café
3 членов
Автор 6 руководств
12 Комментариев
Great documentation, photography was very good.
Jim Brennan - Ответить
wonderful, thank you very much.
Luc Constantin - Ответить
Will a T6 screwdriver work to remove the screws holding the back and hard drive?
Iris R - Ответить
Save the four mounting screws located on the side of the hdd . You will need them for your new hdd.I'm
James Michaud - Ответить
How do I remove those screws? They seem to be permanent placed.
lalof-1 -
Can I remove the old harddrive as instructed above and just have macpro use and external harddrive?
Ron - Ответить
The computer should work fine without a hard drive installed, but you will want a high speed external hard drive that connects over something faster than USB2 in order to have a usable experience. Depending on the model of computer you have, the drive could be connected over Firewire, Thunderbolt, USB3, or USB-C.
David Green -
Once I have my old HD out, how do you transfer the existing OS/files from it to the new SSD drive?
melvinwahl - Ответить
Suggest you install fresh copy of MacOS on another drive, and then run the ‘Migration Assistant’ (found in Applications/Utilities) The Assistant will ask for the source drive and whether you just want documents, or everything, applications, etc.
Hal D -
Excellent descriptions and photos, upgraded from 250GB to 1TB. Thanks!
Base ManDan - Ответить
Excellent-well done.Many thanks from those of us dependent on the kindness of techies
Kevin Quigley - Ответить
Darf man die Schrauben an der Seite der Festplatte entfernen? Ich möchte die Festplatte gerne auslesen, weil da meine ganzen Daten drauf sind. Alle Festplattengehäuse passen leider nicht aufgrund der seitlichen Schrauben. Vielen Dank für Eure Hilfe!
Heike von Fuchs - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 51
За последние 7 дней: 487
За последние 30 дней: 2,288
За всё время: 143,357
