Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Remove the following screws from the port side of rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
Remove the following screws securing the right speaker assembly to the upper case:
One 12 mm Phillips screw.
One 3 mm Phillips screw.
Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
De-route the long antenna from its channel in the rear speaker housing.
Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
Lift the AirPort/Bluetooth board up off the rear speaker assembly.
29 участников успешно повторили данное руководство.
3 Комментариев
Terrific guide; no problems, at all! Don't forget you need to add the Wi-Fi service back to the list of services:
1. Go to System Preferences → Network and click the + button to add a service.
2. Select Wi-Fi as the Interface and provide a service name.
For more info, please see http://apple.stackexchange.com/questions....
Hello!
Does anyone know where I could find this bt card but with Bt 4.0 LE in order to get handoff and continuity to work on this A1342 Macbook?
Thanks!
