Введение
Use this guide to replace fatigue damaged antenna cables routed inside the display.
Выберете то, что вам нужно
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Remove the following screws from the port side of rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Remove the single 3 mm Phillips screw securing the AirPort/Bluetooth antenna ground strap to the rear speaker.
Use the tip of a spudger to pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
De-route the long antenna from its channel in the rear speaker housing.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
There is also a thin metal lock clip under the plastic tab that has to be released ( Use the tip of a spudger ) before you can disconnect the display data cable.
Gently pull the display data cable connector away from its socket on the logic board.
Open your MacBook so the display is perpendicular to the upper case.
Place your opened MacBook on a table as pictured.
While holding the display and upper case together with your left hand, remove the remaining 7.8 mm with lock washer T8 Torx screw from the lower display bracket.
Remove the last remaining T8 Torx screw securing the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
Insert the flat end of a spudger between the thin rubber strip surrounding the front display bezel and the rear display bezel.
Use the flat end of your spudger to carefully pry the front display bezel away from the adhesive securing it to the rear display bezel.
Continue prying until the front display bezel is free along the right side of the display and behind the right clutch hinge.
Use the flat end of a spudger to pry the front display bezel off the top edge of the display assembly.
Continue separating until the top edge of the front display bezel is free from the display assembly.
Use your spudger to pry the left side of the front display bezel away from the display assembly.
Carefully pry up the area behind the left clutch hinge.
Slowly work your way across the lower edge of the front display bezel until it is free from the display assembly.
When you get about half way across, pry up from the other side of the front display bezel's lower edge to ease the process.
Remove the two 3 mm Phillips screws securing the clutch cover to the rear display bezel.
Insert the flat end of a spudger into the open end of the clutch cover and pry up to release it from the rear display bezel.
Remove following six screws securing the LCD to the rear display bezel:
Four 3.4 mm Phillips.
Two 3 mm Phillips.
Hold the display vertically and tip it enough to grab the top edge of the LCD and rotate it slightly out of the display assembly, being careful not to break the circuitry off its lower edge.
Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
Pull the display data cable straight away from its socket on the LCD.
Lift the LCD out of the display assembly and set it aside.
Remove the two small pieces of black tape securing the antenna cables to the rear display bezel.
Remove the four 2.3 mm Phillips screws securing the two antennas to the rear display bezel.
Remove the single 3.3 mm Phillips screw securing the lower antenna ground strap to the rear display bezel.
Carefully pull the antenna cables out from under the frame attached to the rear display bezel and remove them from the display assembly.
8 участников успешно повторили данное руководство.
Один комментарий
What is the trick to reattaching the antenna cables? They appear to be shaped like a hexagon and not circular, but still not able to press them down.
